NB Lola Posted April 11, 2011 Report Share Posted April 11, 2011 I went to open the top of the side hatch (roof cover) and one of the two hinge pins decided not to work with me and sheared off. Now then I am not sure how to extracate it except by drilling - carefully. Tried the usual WD40 and oil left for a while. Tried using another pin to dislodge it. Any ideas on removing it? When I do, where can I source replacement pins? Thanks Link to comment Share on other sites More sharing options...
RLWP Posted April 11, 2011 Report Share Posted April 11, 2011 It's a bit desparate, but you may be able to loosen the rust around the pin by knocking it into the socket. Richard Link to comment Share on other sites More sharing options...
starman Posted April 11, 2011 Report Share Posted April 11, 2011 This place manufacturers all sorts of hinges in Tamworth and is very helpful. They may be able to help re pin. Link to comment Share on other sites More sharing options...
alan_fincher Posted April 11, 2011 Report Share Posted April 11, 2011 Nopt what you want to hear, but...... WE resorted to the drill. Link to comment Share on other sites More sharing options...
Grace and Favour Posted April 11, 2011 Report Share Posted April 11, 2011 try drilling a fine pilot hole into the pin, and then using a screw extractor Link to comment Share on other sites More sharing options...
GBBS Posted April 11, 2011 Report Share Posted April 11, 2011 the hinge will almost certainly be found within the Albert Jagger website. As for saving the hinge i would give it up and get new hinges welded on. they are held in tight enough to break off - do you think you will be able to get them out? Dave Link to comment Share on other sites More sharing options...
Martin Kedian Posted April 12, 2011 Report Share Posted April 12, 2011 the hinge will almost certainly be found within the Albert Jagger website. As for saving the hinge i would give it up and get new hinges welded on. they are held in tight enough to break off - do you think you will be able to get them out? Dave I can post you a pair of these if you like I use them on my retro side doors best wishes Martin [Kedian eng ltd] Link to comment Share on other sites More sharing options...
