Old Son Posted February 25, 2011 Report Share Posted February 25, 2011 My wet room consists of a stainless steel purpose made shower tray which connects to a gulper pump. The tray is about 70mm deep. I have a timber slatted floor which sits in the tray. All looks very nice and no problems with it.......yet!! Link to comment Share on other sites More sharing options...
WotEver Posted February 25, 2011 Report Share Posted February 25, 2011 I would have thought by the time you have problems getting in and out of a bath you will have even more problems getting on and off the boat Your thought would be wrong. I speak from experience. Tony Link to comment Share on other sites More sharing options...
Albion Posted February 25, 2011 Report Share Posted February 25, 2011 One thing that hasn't been mentioned so far, speaking as a boater that has had both types on two different boats, is the fact that with the hip/stepped bath (the one with a seating area at each end) you cannot have a glass shower panel and door, you have to have a curtain. What I found unpleasant was that, when showering with the curtain drawn across, the heat rising caused the shower curtain to be drawn in and you ended up fighting with a cold clammy curtain. With a shower tray you can have a low profile shower door which stays put and also eliminates water leakage. Roger Link to comment Share on other sites More sharing options...
Chertsey Posted February 25, 2011 Report Share Posted February 25, 2011 One thing that hasn't been mentioned so far, speaking as a boater that has had both types on two different boats, is the fact that with the hip/stepped bath (the one with a seating area at each end) you cannot have a glass shower panel and door, you have to have a curtain. What I found unpleasant was that, when showering with the curtain drawn across, the heat rising caused the shower curtain to be drawn in and you ended up fighting with a cold clammy curtain. With a shower tray you can have a low profile shower door which stays put and also eliminates water leakage. Roger That's true. We got rid of the shower curtain and use the shower handheld whilst sitting in the bath. Saves water too. Link to comment Share on other sites More sharing options...
Guest Posted February 25, 2011 Report Share Posted February 25, 2011 One thing that hasn't been mentioned so far, speaking as a boater that has had both types on two different boats, is the fact that with the hip/stepped bath (the one with a seating area at each end) you cannot have a glass shower panel and door, you have to have a curtain. What I found unpleasant was that, when showering with the curtain drawn across, the heat rising caused the shower curtain to be drawn in and you ended up fighting with a cold clammy curtain. With a shower tray you can have a low profile shower door which stays put and also eliminates water leakage. Roger briefly- On a purely pedantic point that is not technically 100% correct. I always thought it was something to do with static but seemingly not. It's explained here. http://www.scienceagogo.com/news/20010613041952data_trunc_sys.shtml Link to comment Share on other sites More sharing options...
Albion Posted February 25, 2011 Report Share Posted February 25, 2011 (edited) briefly- On a purely pedantic point that is not technically 100% correct. I always thought it was something to do with static but seemingly not. It's explained here. http://www.scienceagogo.com/news/20010613041952data_trunc_sys.shtml That doesn't negate my point at all. According to that article the heat from the hot water will rise. The rising hot air will, according to Bernoulli's principle, be rising faster than the air outside the curtain can move and so the pressure inside the curtain will tend to be lower, hence the curtain will move inwards towards the warmer air. Or, if you want, the rising hot air has to be replaced by incoming cold air, particularly towards the bottom of the curtain, and the curtain moves. Nothing to do with static. Bernoulli's applies to aircraft wings and caburettor venturi just as much, or rather, somewhat more than shower curtains. Roger Edited February 25, 2011 by Albion Link to comment Share on other sites More sharing options...
tillergirl Posted February 25, 2011 Report Share Posted February 25, 2011 Shower Cublicle - big enough for two, that should save water - walk thru bathroom - currently just on a wish list. Link to comment Share on other sites More sharing options...
Pretty Funked Up Posted February 25, 2011 Author Report Share Posted February 25, 2011 (edited) when showering with the curtain drawn across, the heat rising caused the shower curtain to be drawn in and you ended up fighting with a cold clammy curtain. Roger haha sooo true I cured that on mine by using a curved shower curtain rail. Each end lines up with the bath but curves right out inbetween. No more clammy curtain fights I do like the wet room thingy, always did just knew it would be a b'stard to achieve. Going to have some more thought about that one again. A shower 'big enough for two' I think I can just about pull off, I was looking at those double width trays initially and it would just over hang the door entry by a few inches, which I know I could get round if I decided to go with that design.... Edited February 25, 2011 by Pretty Funked Up Link to comment Share on other sites More sharing options...
jelunga Posted February 25, 2011 Report Share Posted February 25, 2011 I am quite happy to share any lady's bath!! It seems to me that the ladies prefer baths and the men showers from this thread ..... Link to comment Share on other sites More sharing options...
ymu Posted February 25, 2011 Report Share Posted February 25, 2011 I am quite happy to share any lady's bath!! Two people in a narrowboat bath ... that really would save water, there'd be no room left for any in the tub! Link to comment Share on other sites More sharing options...
