serenility Posted January 7, 2011 Report Share Posted January 7, 2011 Linky I want to put a longer length of co-ax onto this aerial, but it has resisted all my efforts to separate the top and bottom plastic bits. Anyone got any ideas before I break it? Link to comment Share on other sites More sharing options...
OldGoldy Posted January 7, 2011 Report Share Posted January 7, 2011 (edited) Linky I want to put a longer length of co-ax onto this aerial, but it has resisted all my efforts to separate the top and bottom plastic bits. Anyone got any ideas before I break it? Can only suggest blunt knife, screwdriver & patience whilst progressing around shell joint OR alternatively use co-ax jointing box/connectors & extra cable + fill any resulting gaps with Copydex or self-amalgamating tape Edited January 7, 2011 by dave69700 Link to comment Share on other sites More sharing options...
frangar Posted January 7, 2011 Report Share Posted January 7, 2011 I have a Status "UFO" type aerial...the type found on most caravans etc....and although that has screws I have never managed to get it apart...resorted to making a joint that fitted in the mast that its attached on top of....When I asked Status they said it cant be taken apart....which wasnt very helpful!!... Gareth Link to comment Share on other sites More sharing options...
bottle Posted January 7, 2011 Report Share Posted January 7, 2011 See second line of post #2. Will cost pennies but will save a lot of frustration and having to buy a new aerial when the old one is knackered damaged. Link to comment Share on other sites More sharing options...
frangar Posted January 7, 2011 Report Share Posted January 7, 2011 See second line of post #2. Will cost pennies but will save a lot of frustration and having to buy a new aerial when the old one is knackered damaged. Indeed...or when the co-ax melts cos its gone across the outlet of the Alde............ Gareth Link to comment Share on other sites More sharing options...
Martyn Hicks Posted January 7, 2011 Report Share Posted January 7, 2011 Linky I want to put a longer length of co-ax onto this aerial, but it has resisted all my efforts to separate the top and bottom plastic bits. Anyone got any ideas before I break it? Hi May be best to cut the cable and insert the extra length that you wanted, if any of the joints are outside use algamating waterproof tape.. You should find that a couple splits shouldn't cause that much damage in any signal loss... I have to do it sometimes with satellite, last job I did, we used a dish fixed on the bankside and a cable run 150 feet with 2 joints before it went into the boat and no issue's with the signall quality... Martyn.... Link to comment Share on other sites More sharing options...
Bob the welder Posted January 7, 2011 Report Share Posted January 7, 2011 Linky I want to put a longer length of co-ax onto this aerial, but it has resisted all my efforts to separate the top and bottom plastic bits. Anyone got any ideas before I break it? hi .in the wheel pic what engine is it ?. bob Link to comment Share on other sites More sharing options...
serenility Posted January 7, 2011 Author Report Share Posted January 7, 2011 hi .in the wheel pic what engine is it ?. bob ;Enterprise' by Martin Evans 5" guage LNER V1/3 2-6-2tank engine Link to comment Share on other sites More sharing options...
Bob the welder Posted January 7, 2011 Report Share Posted January 7, 2011 ;Enterprise' by Martin Evans 5" guage LNER V1/3 2-6-2tank engine thanks .i got a 7.25 going aroud the garden .but it is a 0 8 0 deisle . have fun .all best .bob Link to comment Share on other sites More sharing options...
