gaggle Posted April 7, 2008 Report Share Posted April 7, 2008 in february last year my fuel pump packed in and canal river rescue put a new one on at a charge of £40/60 , cant remember exactly. after the engine packed up again last saturday i looked around and seen that pump had come off the mounting and it was resting on the gear box , a wire had come loose from its electric supply and when it was pushed back together the pump began to work it seems but after 1 mile moveing the pump packed in altogether and once again canal and river had to replace it with another pump. the engine from new has 1600 hours on the clock , is it normal for two fuel pump changes to be needed in such a time frame of usage. should a pump supplied last longer than twelve months. Link to comment Share on other sites More sharing options...
riverbargeman Posted April 7, 2008 Report Share Posted April 7, 2008 in february last year my fuel pump packed in and canal river rescue put a new one on at a charge of £40/60 , cant remember exactly.after the engine packed up again last saturday i looked around and seen that pump had come off the mounting and it was resting on the gear box , a wire had come loose from its electric supply and when it was pushed back together the pump began to work it seems but after 1 mile moveing the pump packed in altogether and once again canal and river had to replace it with another pump. the engine from new has 1600 hours on the clock , is it normal for two fuel pump changes to be needed in such a time frame of usage. should a pump supplied last longer than twelve months. What engine? Mitsubishi? Link to comment Share on other sites More sharing options...
gaggle Posted April 7, 2008 Author Report Share Posted April 7, 2008 barris shire 45 Link to comment Share on other sites More sharing options...
Glennbrown Posted April 7, 2008 Report Share Posted April 7, 2008 same happened to me last week on a barrus engine 1650 hr got one of ebay £56 (barrus £150) i think u should keep one as a spare Link to comment Share on other sites More sharing options...
gaggle Posted April 7, 2008 Author Report Share Posted April 7, 2008 are they a standard item or are they different for engine types/sizes. the fella from canal and river last year said the one he was putting on would last for years so i never got me a spare one. Link to comment Share on other sites More sharing options...
Troll Posted April 7, 2008 Report Share Posted April 7, 2008 I have had the same with barrus also so it must be a fault I never had a car with such a shortlifespan pump Link to comment Share on other sites More sharing options...
saltysplash Posted April 8, 2008 Report Share Posted April 8, 2008 in february last year my fuel pump packed in and canal river rescue put a new one on at a charge of £40/60 , cant remember exactly.after the engine packed up again last saturday i looked around and seen that pump had come off the mounting and it was resting on the gear box , a wire had come loose from its electric supply and when it was pushed back together the pump began to work it seems but after 1 mile moveing the pump packed in altogether and once again canal and river had to replace it with another pump. the engine from new has 1600 hours on the clock , is it normal for two fuel pump changes to be needed in such a time frame of usage. should a pump supplied last longer than twelve months. The only fuel pump ive ever had to replace was on a VW Scirocco......sorry, not much help but so far touch wood, in 30 yrs ive never had to replace a fuel pump on a marine engine.....plenty of other items but never a fuel pump......ooopppsss sorry.....also forgot i replace the pump on a 1962 Mini Van once Link to comment Share on other sites More sharing options...
Liam Posted April 8, 2008 Report Share Posted April 8, 2008 We had one failed shortly after we bought the boat in 2005 which we obviously replaced but then had that one go last October about 2 years later... We're on our 3rd at the moment so lets see how long this one lasts!! Link to comment Share on other sites More sharing options...
Chris Pink Posted April 8, 2008 Report Share Posted April 8, 2008 in february last year my fuel pump packed in and canal river rescue put a new one on at a charge of £40/60 , cant remember exactly.after the engine packed up again last saturday i looked around and seen that pump had come off the mounting and it was resting on the gear box , a wire had come loose from its electric supply and when it was pushed back together the pump began to work it seems but after 1 mile moveing the pump packed in altogether and once again canal and river had to replace it with another pump. the engine from new has 1600 hours on the clock , is it normal for two fuel pump changes to be needed in such a time frame of usage. should a pump supplied last longer than twelve months. My take was that a part that spends its life soaked in diesel (which i will learn to spell first time one day) like a fuel pump would have an almost indefinite lifespan. I suppose that mountings and wiring isn't really covered by that. Suspicious minded Pink ponders... did they put it in right? Unsuspicious Pink says, well if something's going to go wrong then it will probably happen early in its life. Link to comment Share on other sites More sharing options...
Glennbrown Posted April 8, 2008 Report Share Posted April 8, 2008 The type of fuel pump on the barrus range is very common for agricultural vehicles ie dumper trucks etc I woud move the pump which is mounted on the engine since i believe the vibration kills these pumps Link to comment Share on other sites More sharing options...
larkshall Posted April 8, 2008 Report Share Posted April 8, 2008 The type of fuel pump on the barrus range is very common for agricultural vehicles ie dumper trucks etc I woud move the pump which is mounted on the engine since i believe the vibration kills these pumps Yes vibration does kill them dead. \\\\just a thought, anyone dismantled a failed pump? curious as to what is likely to have failed. Favourite would be a foreign body somewhere (had a pump go on a massey combine, turned out to be swarf had got in somehow, and caused the pump to jam and burn out. But like other posters have had very little problem with pumps in 40 years( Except for su pumps in cars that is anyone from jag owners club will cnfirm they where a b****r). Link to comment Share on other sites More sharing options...
