PNB116 Posted February 15 Report Share Posted February 15 Dear all, ‘’I hope that you can help me with some suggestions. My bilge pump (narrowboat) has packed up, the auto feature isn’t working and thinks that it is always under water. The same one at Midland Chandlers is £65. As this is the second one to fail I was wondering what bilge pump people would recommend? many thanks Paul Link to comment Share on other sites More sharing options...
Tony Brooks Posted February 15 Report Share Posted February 15 32 minutes ago, PNB116 said: Dear all, ‘’I hope that you can help me with some suggestions. My bilge pump (narrowboat) has packed up, the auto feature isn’t working and thinks that it is always under water. The same one at Midland Chandlers is £65. As this is the second one to fail I was wondering what bilge pump people would recommend? many thanks Paul There are several different designs of automatic bilge pumps, depending upon how the water level is sensed. A remote float switch, an electronic level sensor, or one that pulses the pump every xx minutes and decides by the current draw if it is pumping or just spinning. Oil & grease can cause problems for all types, so make sure the bilge is clean and oil/grease free. Unless we know what type of system your pump uses, how can we make a recommendation. It is perfectly possible that all you might need to do is remove debris from the float switch, if it is that type. If it is running all the time, perhaps fitting a remote float switch may be cheaper than a new "fancy" pump. PS, do you have a three position, pump switch, if so you may have set it to run all the time. Link to comment Share on other sites More sharing options...
Arthur Marshall Posted February 15 Report Share Posted February 15 5 hours ago, PNB116 said: Dear all, ‘’I hope that you can help me with some suggestions. My bilge pump (narrowboat) has packed up, the auto feature isn’t working and thinks that it is always under water. The same one at Midland Chandlers is £65. As this is the second one to fail I was wondering what bilge pump people would recommend? many thanks Paul Every auto bilge pump I've had in thirty years has failed when it was needed. Admittedly only three times, I think, but the first time sank the boat, the third would have done if the bloke using the boat hadn't driven halfway round the 4 counties with it on permanent manual. I just don't trust them any more and treat the auto feature as a backup which might, but probably won't, work. Link to comment Share on other sites More sharing options...
cheesegas Posted February 17 Report Share Posted February 17 Avoid the float type - I'd recommend the Rule ones with an electronic water sensor and no moving parts, not cheap though at around £80. Had mine for the 4 years I've had the boat plus however long it was installed before that...1 year of my ownership I had a leaky stern gland and it's still going strong and the bearings still sound good. The sensor never fails to activate the pump no matter how much crap collects in the bucket under the gland, but I do regularly clean the pump. Link to comment Share on other sites More sharing options...
Tracy D'arth Posted February 17 Report Share Posted February 17 The best bilge pump is a desperate man and a bucket. 2 Link to comment Share on other sites More sharing options...
