Rev David Posted January 26 Report Share Posted January 26 Hi, I have a Mowog AI 9H9 1500 Diesel engine fitted on my boat. The plate (in the pic) is leaking oil. It appears to have a green sealant around it. Should be cork and would anyone know the dimensions or where I could obtain one please. Many thanks Link to comment Share on other sites More sharing options...
Tracy D'arth Posted January 26 Report Share Posted January 26 53 minutes ago, Rev David said: Hi, I have a Mowog AI 9H9 1500 Diesel engine fitted on my boat. The plate (in the pic) is leaking oil. It appears to have a green sealant around it. Should be cork and would anyone know the dimensions or where I could obtain one please. Many thanks That is the rear tappet chest cover on a BMC 1.5D engine. Originally they had cork but most modern head gasket sets have red silicone rubber ones in. ASAP or Calcutt will have them, they are the same on all smaller BMC engines petrol or diesel so an original Mini one is the same for instance. Link to comment Share on other sites More sharing options...
Rev David Posted January 26 Author Report Share Posted January 26 3 minutes ago, Tracy D'arth said: That is the rear tappet chest cover on a BMC 1.5D engine. Originally they had cork but most modern head gasket sets have red silicone rubber ones in. ASAP or Calcutt will have them, they are the same on all smaller BMC engines petrol or diesel so an original Mini one is the same for instance. Thanks so much Tracy. Really appreciate your time and advice. Link to comment Share on other sites More sharing options...
Moke Posted January 26 Report Share Posted January 26 If they are the same as the A series ones, and from the picture they are, I found them on the minispares website at £1.24 each. BTW minispares are at the higher quality/price end of the market. You should also fit the seals on the bolts. Part numbers 12A1175 for the large one, 12A1176 for the small. Link to comment Share on other sites More sharing options...
Tracy D'arth Posted January 26 Report Share Posted January 26 Try the MGB specialists too, Moss Motors. The seal on the bolt is a plain fibre washer or a rubber "O" ring will do. Don't over tighten the bolt or the cover distorts and will leak again. Link to comment Share on other sites More sharing options...
Tony Brooks Posted January 26 Report Share Posted January 26 (edited) 7 minutes ago, Tracy D'arth said: Try the MGB specialists too, Moss Motors. The seal on the bolt is a plain fibre washer or a rubber "O" ring will do. Don't over tighten the bolt or the cover distorts and will leak again. Hard to tell, but looking at the way the pain seems to have flaked off around the bolt head, I think it may already have distorted (dished). If so, turn it upside down onto a flat surface and use a small hammer or hammer and drift to flatten out the dish from the inside. You may have to re-drill the hole. Certainly take care not to distort it again. It all looks very oily, even above the cover, so check that the rocker cover gasket is not leaking. It is well hidden by the marine manifold, so you may need a length of bent wire to gently probe the gap between head and cover in case the gasket has slipped inside. FWIW, in latter years I tended to stick the gasket to the cover with silicon gasket sealer because the cork ones always distorted, but nowadays you can get silicon ones that hold their shape better. Edited January 26 by Tony Brooks Link to comment Share on other sites More sharing options...
Mikexx Posted January 27 Report Share Posted January 27 20 hours ago, Tracy D'arth said: they are the same on all smaller BMC engines petrol or diesel so an original Mini one is the same for instance. That's really useful to know. I've only just got some cork ones from Calcutt boats Link to comment Share on other sites More sharing options...
