Does anyone know if there is a pre-made gasket available for the injector cover? Or will I need to make one? Lister HB3
Thanks
Edited by Ca Jon
Talk to Marine Engine Services (Midlands) . @RLWP on here.   The gasket is probably part of a top end set or an overhaul set.
N
N
Thank you, will do. I might be able to cut one out of a cork sheet....
Fuel pump door joint. If you are lucky, we have some old 'card' ones about which are far easier to fit
Richard
Richard
Thank you Richard. How do I order one?
Richard
That is what I thought it was rather than an injector cover, but not knowing the HA in any detail kept my mouth shut.
I believe you ring them up and speak to Sue.  Google will find the phone number.
N
Thank you.
I wasn’t sure what it was called. It covers access to the injectors and rail, but good to know what it’s called. Thank you.
58 minutes ago, Ca Jon said:
Thank you.
I don't think so, the injectors are high up on the engine. It covers the injector PUMPs and rail. The injectors might be under the rocker covers, but not sure on the HA.
N
Spoke with Sue and gasket ordered. Thank you all for your help
Gasket ordered from  https://www.primrose-engineering.co.uk
For those interested, the part description/ number is.  HB3 Fuel pump door joint gasket 353-15460
Thank you everyone.
