roland elsdon Posted January 29, 2023 Report Share Posted January 29, 2023 Our stove does this. We burn smokeless or bricketts. There is no leak at the top . Does it in dry weather Only with very low fire. Assume it is related to condensation on outside of single wall flue. very small fire very long flu. Yes I have 3 co detectors Yes l have beaten the living daylights out of the stove pipe at the join with the collar both internaly and externally to check the flue, with a hammer. Done it since first being lit. Link to comment Share on other sites More sharing options...
Tony Brooks Posted January 29, 2023 Report Share Posted January 29, 2023 1 hour ago, roland elsdon said: Our stove does this. We burn smokeless or bricketts. There is no leak at the top . Does it in dry weather Only with very low fire. Assume it is related to condensation on outside of single wall flue. very small fire very long flu. Yes I have 3 co detectors Yes l have beaten the living daylights out of the stove pipe at the join with the collar both internaly and externally to check the flue, with a hammer. Done it since first being lit. Do you have a double skin chimney with the inner slightly set down into the flue and the gap between the inner and outer insulated? I think often the drips originate inside a single skin chimney, drip down onto the collar and leak between collar and flue. 1 Link to comment Share on other sites More sharing options...
YSA Posted January 29, 2023 Author Report Share Posted January 29, 2023 14 hours ago, rusty69 said: Did you manage to get this sorted? Someone is coming to have a look next week hopefully! I think it's just some fire cement that's come off and has left some gaps, but the steel at the flue collar is a little wobbly so want to make sure it's all ok, especially as I'll be away for s bit and someone else will be staying on the boat! Link to comment Share on other sites More sharing options...
rusty69 Posted January 29, 2023 Report Share Posted January 29, 2023 8 minutes ago, YSA said: Someone is coming to have a look next week hopefully! I think it's just some fire cement that's come off and has left some gaps, but the steel at the flue collar is a little wobbly so want to make sure it's all ok, especially as I'll be away for s bit and someone else will be staying on the boat! Great. Thanks for coming back. Hope you get it sorted, and its nothing major. Link to comment Share on other sites More sharing options...
