Hi all,
I need to get a new joint for my STW3 thermostat housing. Part number 202-91080. Its the gasket or seal that goes between these two parts of the housing:
I am fairly sure I can make one from Neoprene, cork or paper, but the old material has decayed to the point that I cannot even identify what it was made of!
Anyone know?
Cheers!
Chris,
Edited by nbbranwell
If my memory serves me I think that they were a made of a card type gasket material a couple of mm thick. Mind you I don't think it make to much difference whatever you use.
Wheaty packets, soaked in oil, work fine, but you can buy 300 mm square sheets of gasket material on line.  Klingerit is a good name. 1 mm thick is likely to be plenty.  2 mm thick  gasket material is like cutting lino.
N
