Bod Posted June 28, 2021 Report Share Posted June 28, 2021 On 08/06/2021 at 20:08, manxmike said: I found this on line re Microbiologically Induced Corrosion: MIC is caused by biological growth, i.e. organic slime (typically bacteria, algae, and fungi) in water under low flow or stagnant conditions. The industry experiences it in cooling water systems, piping, vessels and storage tank bottoms where the conditions are ripe for it. MIC manifests itself as pits, often under deposits, tubercles, or slime. These pits sometimes have the unique characteristic (which often makes MIC readily identifiable) of subsurface “caverns” that are larger than the pitted opening to the surface. The MIC “bug” can affect most any type of construction material, but is most often a problem with carbon steel and 300 series stainless steel, partially because those are the two most common construction materials. Not infrequently MIC strikes when equipment that has been hydrotested is not completely drained and dried and kept dry before installation or use. An effective specification, procedure and management system is necessary for hydrotesting in order to make sure that those involved know that the MIC “bug” is waiting to bite the uninformed. One of the reasons MIC is so insidious is that it can “drill through” a pipe or tube in a matter of days or weeks, if equipment is left with stagnant, untreated water in it. Imagine your unhappy surprise when a piece of equipment that was hydrotested 6 weeks ago is now ready to be put in service and in so doing, it sprays liquid out like a shower nozzle. Aluminum, 300 series SS’s, brass and carbon steels are especially vulnerable to MIC. As you might expect, the proper treatment for preventing MIC in water systems is the application of biocides that kill the organic compounds. Now you know, if you didn’t already, the primary reason why chlorine or chlorinated compounds are added to CWT’s. The MIC bugs thrive when their CWT’s are inadvertently contaminated with hydrocarbons, or when someone temporarily stops the chlorination without knowing the potential consequence of their actions. Firewater systems that are not adequately treated with biocides often give rise to MIC, especially when firewater is used for hydrotesting and the equipment is not adequately drained and dried. Are all the right people at your facility aware that through-wall pitting penetration by MIC can happen very rapidly under stagnant water conditions in storage tanks, and in equipment left with standing water (with biological contamination) after hydrotesting and during temporary shut downs? As this is caused by Microcrobes, would a high temperture Steam pressure wash, effectively sterilise the hull? Bod Link to comment Share on other sites More sharing options...
Alan de Enfield Posted June 28, 2021 Report Share Posted June 28, 2021 9 minutes ago, Bod said: As this is caused by Microcrobes, would a high temperture Steam pressure wash, effectively sterilise the hull? Bod Possibly, but, Microbes live in and around hydrothermal volcanic vents on the ocean floor and temperatures are considerably above 'steam' temperature. Link to comment Share on other sites More sharing options...
matty40s Posted June 28, 2021 Report Share Posted June 28, 2021 1 hour ago, Alan de Enfield said: Possibly, but, Microbes live in and around hydrothermal volcanic vents on the ocean floor and temperatures are considerably above 'steam' temperature. Ah but, the ocean floor is still there.... 1 Link to comment Share on other sites More sharing options...
