dacaB Posted October 9, 2007 Report Share Posted October 9, 2007 The overall width of a narrow boat is 6' 10" ish, OK. I am searching for inches on my 'plan'..........so, what is the planning width of the interior at floor level , at (worktop height), and at gunnel height. I doubt that the obvious 6' figure is very accurate There doesn't seem to be much point in placing 'things' on the plan if they will not fit in reality. Thanks in advance. Link to comment Share on other sites More sharing options...
Speedwell Posted October 9, 2007 Report Share Posted October 9, 2007 The overall width of a narrow boat is 6' 10" ish, OK. I am searching for inches on my 'plan'..........so, what is the planning width of the interior at floor level , at (worktop height), and at gunnel height. I doubt that the obvious 6' figure is very accurate There doesn't seem to be much point in placing 'things' on the plan if they will not fit in reality. Thanks in advance. There will not be a fixed internal width. It depends on the thickness of the insulation and lining material and on the width of the gunwhale. Arthur Link to comment Share on other sites More sharing options...
Gary Peacock Posted October 9, 2007 Report Share Posted October 9, 2007 The overall width of a narrow boat is 6' 10" ish, OK. I am searching for inches on my 'plan'..........so, what is the planning width of the interior at floor level , at (worktop height), and at gunnel height. I doubt that the obvious 6' figure is very accurate There doesn't seem to be much point in placing 'things' on the plan if they will not fit in reality. Thanks in advance. And there you have a common problem, nearly every boat is different if you know who's going to build it then they can give you a good idea but before you make a decision on builder it can be a bit hit and miss. Link to comment Share on other sites More sharing options...
ChrisPy Posted October 9, 2007 Report Share Posted October 9, 2007 and the answer is that the internal width is always less than you think. ....................... sod's law. Link to comment Share on other sites More sharing options...
bottle Posted October 9, 2007 Report Share Posted October 9, 2007 As has been said, it will vary from boat to boat. If you are doing a basic plan then the actual dimension will not matter, I just used, for example, two feet square boxes for the kitchen galley. I am having it built so will not have the hassle of making it all fit in. Not very helpful sorry but why are you searching for inches in the width. (Ribald comments not required ) Link to comment Share on other sites More sharing options...
dacaB Posted October 9, 2007 Author Report Share Posted October 9, 2007 Thanks all, took advice and talked to a chap called Mike at L&J, he was very helpful and generous with his time. He gave me a working width and lengths ( he was on the other end of a phone line Mr B ) that included well/fore deck, cabin and rear deck. It turns out my guestimations were surprisingly accurate Link to comment Share on other sites More sharing options...
blackrose Posted October 9, 2007 Report Share Posted October 9, 2007 and the answer is that the internal width is always less than you think. ....................... sod's law. Speak for yourself Link to comment Share on other sites More sharing options...
ChrisPy Posted October 10, 2007 Report Share Posted October 10, 2007 Speak for yourself they weren't offering supa-wide beams when I ordered. you're just a Johnny come lately Link to comment Share on other sites More sharing options...
RobinJ Posted October 10, 2007 Report Share Posted October 10, 2007 and the answer is that the internal width is always less than you think. ....................... sod's law. Or more! That dreaded 2" gap Link to comment Share on other sites More sharing options...
skylark Posted October 10, 2007 Report Share Posted October 10, 2007 ok, call me picky but does anyone know if the 6' 10" usually includes the rubbing strakes? thanks, martin Link to comment Share on other sites More sharing options...
blackrose Posted October 10, 2007 Report Share Posted October 10, 2007 they weren't offering supa-wide beams when I ordered. you're just a Johnny come lately At least my boat's in the water! Link to comment Share on other sites More sharing options...
John Orentas Posted October 10, 2007 Report Share Posted October 10, 2007 Remember also the hull sides are rarely parallel, mine has a good 1.5" 'lean out' on each side. (Measured at gunwhale level). Link to comment Share on other sites More sharing options...
ChrisPy Posted October 11, 2007 Report Share Posted October 11, 2007 (edited) At least my boat's in the water! I have nothing to say in my defence, your honour. PS I'm saving on anodes Edited October 11, 2007 by chris polley Link to comment Share on other sites More sharing options...
John Orentas Posted October 11, 2007 Report Share Posted October 11, 2007 Remember also the hull sides are rarely parallel, mine has a good 1.5" 'lean out' on each side. (Measured at gunwhale level). Hi Daca. Are we to understand you need this information to enable you to carry out some form of self fit-out.. If so a very good thing to do when you have your boat is to make an accurate boat side template, incorporating the cabin tumble home and all other detail including a true vertical datum. Armed with this you can confidently build furnishings and any other stuff away from the boat and to sure they will fit neatly into place without further adjustment /trimming /hacking. Link to comment Share on other sites More sharing options...
David Schweizer Posted October 11, 2007 Report Share Posted October 11, 2007 (edited) Hi Daca. Are we to understand you need this information to enable you to carry out some form of self fit-out.. If so a very good thing to do when you have your boat is to make an accurate boat side template, incorporating the cabin tumble home and all other detail including a true vertical datum. Armed with this you can confidently build furnishings and any other stuff away from the boat and to sure they will fit neatly into place without further adjustment /trimming /hacking. To that advice. I would add - make prolific use of cardboard templates for all the furniture, and purchase a Builder's Square. When I re-fitted my boat I discovered that with tumble home and swims, there isn't a right angle present and designing furniture to fit requires carefull measurement before you commence any work. Cardboard templates can be made easily on site, and taken home where the timber panels can be fabricated in your workshop. If the templates have been made carefully the timber panels will require only minimal adjustment before they fit perfectly. Spriit levels and plumb lines are useless on a boat, which is where the builder's Square comes into play, If all the verticals are at right angles to the floor, horizontals can be measured with a straight edge. This sometimes requires some ingenuity if you are working alone, 56lb weights and timber packing will help hold the square stedy whilst measuring the horizontals. Good luck, let us know how you get on. Edited October 11, 2007 by David Schweizer Link to comment Share on other sites More sharing options...
