I agree about propane v butane but cooling seems to satisfy the symptoms. It's not the outside temperature that counts, it's how fast and how long the gas boils and how well insulated the bottle is. With butane, at scout camp, I have had to shake and warm the bottle even on a relatively mild evening. I have just looked up the boiling point of propane, which is -42C, so a bit of a stretch, but can be easily checked by shaking the bottle.
You said it was a very cold night. As the liquid propane boils off, for you to use as gas, it cools the rest of the bottle. It could be that you are cooling the bottle so low that there is insufficient gas pressure to drive your stove. Probably the top of the liquid cools most, so shaking the bottle will increase the surface temperature and the gas will flow again. Overnight the temperature will have equalised naturally.
I managed mine with a slimmed down 13mm open ended spanner. Worked well in reducing smoke. You need to move it in the opposite direction to its rotation, which is in the same direction as the engine rotation.
Bit late joining this discussion but I fitted all 8 seals to my Calcutt Turkish 1.8 and an exhaust valve seized in its guide after about a quarter of a mile on its first test run. I think inlet only is correct. I hate to tempt fate but it has run for 12 years since.
i also found that British rings do not fit the German pistons, used in the Turkish engines, Fortunately you seem to be passed this stage.
Arthur
We had one made by a local plastic moulding company (Near Blackpool) who made a mould from the old one. A different company tried to make one from a drawing but the end product bore little resemblance to the drawing and I wouldn't pay for it.
Arthur
Hopefully this will be a picture of us at Fotheringhay to prove that we got there.
Arthur
https://plus.google.com/photos/105499103977382287553/albums/6064067767073519457
Sadly only works as a link
I broke one a few months ago and got a spare from AMC diesel at Longton, phone 01772 613003. They used to build the BMC engines there and own the Thornycroft name. They are usually very helpful. The screws are incredibly expensive for such a little thing, presumably because of their rarity value.
Arthur
If you Google "british standard colours" you can get a lot of info and BS numbers for paint colours. Craftmaster can mix to any standard colour, as can other paint companies. Here is an example website. http://www.e-paint.co.uk/BS381%20Colourchart.asp
Arthur
