Sign in to follow this
Roxylass
Dipstick possibly
Removed the crank case side plate to drain the remaining oil from the sump
where this bolt is screwed on could this be a dipstick holder
Share this post
Yes, alternative for some industrial installations usng a short dipstick.
Share this post
And that's almost certainly an industrial door. Notice the bolts to mount a filter
Richard
Share this post
Richard
And the alternative oil filler cap.
Share this post
As you know the engine in question is a Lister sr2 marine
is this the correct side plate for it
it fits perfectly well
I acquired a small dipstick from sleeman/hawken maybe see if it fits
allthough quite sure that Richard said it was for cement mixer/dumper
sure there is a couple of pics of it in another thread I made entitled oil dipstick/dipstick
thanks for your help once again mr bizzard
Share this post
The door has been drilled and a brass plug fitted, meaning you probably won't be able to fit the sleeve to the door for the dipstick
It's probably a door for an SR2, not a marine SR2
I don't have my dipstick identifier handy to say if a #6 is the correct one
Would you like me to check if we have an SR2 door with an intact dipstick tube?
Richard
Share this post
A world class car maker supplied my research department with their latest design of I.C. engine, brand new and complete but dry.
When fitted onto our state of the art dynomometer rig it lasted all of two minutes before siezing solid.
It turned  out that some plonker had factory fitted the wrong dipstick so when we commisioned the engine it didn't have anywhere near enough oil in it despite what the dipstick said!
So if you decide to fit a dipstick make sure you have the right quantity of oil in the engine first and only then mark your shiny new dipstick with the correct level.
Share this post
That would be very much appreciated Richard
will it have the mounting for the lifting pump as you can see in the pic
to the left of the cap
thank you for your help
Share this post
The safe way to make sure you have the right dipstick is to drain all the oil out and refill with te correct amount, SR2 is about 9 pints, and then see if the dipstick registers correctly.
Share this post
I shall bizzard
you gave me terrific advice on how to make one
i have the copper rod and the mecanno pulley wheel
just need to find the right sized rubber grommet now
Share this post
5 minutes ago, Roxylass said:
I shall bizzard
Copper rod? You need steel rod, 1/8'' welding rod works well.
Share this post
You might be in luck @Roxylass. I had a search the other day and found only simple door. Yesterday, I stumbled across this:
It's a brand new two cylinder crankcase door, it would need dressing up because it is a machined casting only. No studs, oil filler (or blank), fuel pump guide or threaded oil filter tube
I don't know if I have the internal oil pipes for the filter, I do have a blanking plate
Richard
Share this post
