Durhamdales
Everything posted by Durhamdales
  1. A large chain wrench wrapped around the old flu is what you need - bigger the better!
  3. He did the whole thing? In which case the NBW headline should be 'Richard Parry does the Full Monty'
  4. We moored there for a week last year and I thought that the people running it were just plain rude. We had booked in advance, but were yelled at when we entered the marina and were told (yelled across the marina) 'you don't get nothing - no power, no water, nothing' We were then told that we couldn't leave a car there for the weekend. The staging was really flimsy and the whole place needed a good sorting out I've got a feeling it might have changed hands since?
  5. I had a pump out on my first boat, a Springer. We stopped on The Thames at Wallingford for a pump out. The engineer claimed that he felt that his pump was sucking in air - he was right, the suction had pulled the bottom of the tank in! Being a vee bottom, the entire contents had gone into the bilges, some of it being absorbed into the rust that was also present - the vast majority ended up in the stern. We knew that because the bilge pump was pumping out blue liquid! The end of the family holiday for that year..................
  6. One for the marina moorers on a hook up - turn off the battery charger
  7. If you are in Brum, I would recommend RN Diesels (no relation) in Wolverhampton 01902 450912 They will take a look at your injectors and reset/refurb as required. They are not fazed by old kit either
  8. Sherborne Wharf is very secure, but not that cheap
  9. You could probably hire a smallish air compressor - the sort used for power tools?
  10. Can you attach an air line and blow it through?
  11. I have a feeling it might be something to do with the alignment - the short piece of shaft between the stuffing box and the centraflex coupling is very greasy - I didn't notice this before and I'm wondering if it due to heat as it passes through the stuffing box - although it was easy enough to turn the prop via the weedhatch. I have noted that the engine is fitted on tall hardwood risers (this engine sits a lot higher than the Kelvin), but there doesn't seem to be any shims fitted. This means that either the wood blocks were machined exactly as required, or (more likely), they were relying on the centraflex to take up any misalignment. If this has was excessive, then I guess it may have knocked out the bearing in very short order - it certainly wasn't doing it for the first 15 hours or so of use.
  12. Thanks Richard To get to the bearings that may be faulty - does that normally necessitate gearbox removal - or is it something at the back of the box that may be accessible in situ?
  13. It's a brand new propshaft running through the original (now repacked) stern tube. It certainly didn't do it the first time we took her out. Richard - I'm in uncharted territory here - could this be a problem of misalignment? The bearings you referred to taking the brunt of it? That clonk going into gear - is that a common PRM thing?
  14. Water leaking through Cowley would increase the water level! That's one hell of a long pound to drop due to a leaky gate at Camden! Must be more to it than that surely!
  15. RLWP - I meant the shaft coming out of the gearbox and into the coupling - and then the propshaft running through the stern tube I can kind of see why there would be more wear in ahead than astern - in which case it would not do it in reverse. But a 'prop clearing squirt of reverse' seems to clear it? MTB - Yes we gave up on the Kelvin P4
  16. There have been a few issues with the chargers on these things Have a look at this video http://metro.co.uk/2014/04/08/video-e-cigarette-explodes-in-barmaids-face-after-being-put-on-ipad-charger-4692238/ There was a phone in about it on Radio 2 the other day, apparently they can be supplied without a charger (which I found incredible) and then people use the wrong ones - but with the same fittings. For those of us (like me) that have bought cheap USB based cables on ebay rather than paying Apple for the real thing - there were also lots of horror stories.
  17. There is a Centraflex coupling fitted - but both shafts are very short. Its tight to the stern of the boat Its a PRM 260 Still can't fathom why reverse would clear it - but I don't know anything about PRM boxes!
  19. Hi Mike It does vary with engine speed - but you can't rev through it so that it disappears
  20. Hi Folks. Last year we had a refurbed Perkins D3 with a 2:1 PRM (also refurbished) fitted. At the same time the prop shaft was changed and the packing renewed. We only picked it up at the end of last season and it had about 12 hours of running back to base - and then we took her out again this weekend. On Friday we had this loud harmonic sound that seemed to start when the engine was put in gear to pull away out of a lock; it did this twice. It didn't seem to go when additional revs were put on - what seemed to shift it was a sharp rev in reverse. I checked the weedhatch and there was only some light weed around the shaft. I could turn the prop in neutral by hand through the weedhatch. I did notice on our return that the noise did seem to build up slowly - but a quick rev in reverse seemed to clear it. Some possibly useful (most likely useless!) additional info The prop was not changed at the time the engine was changed, to my knowledge, it has not been 'clonked' against anything hard - but it may not be the ultimate size for the boat now. The stern tube does not leak a drop in forward, but I note does drip in reverse I'm not sure if the shaft is getting warm as there does seem to be some grey grease on the shaft between the stuffing box and the centrafex coupling The engine is on solid mounts. There is a 'clonk' when engaging gears - I have had this before on a PRM, but its not a comfortable sound! It does seem like a prop singing noise - but why would it clear itself when reversed, unless it is a slow build up of crap on the blades? Any ideas very welcome Thanks
  21. We struggled with the standard narrowboat solution of a 4' double bed - especially when it tucks under the gunnel. Luckily we have a rear engine room and the bed is just in front of this. I simply used some slide out boards to extend the bed width - I had to screw a bearer to the gangway side for them to rest on. We then bought two 3' mattresses and have a huge 6' wide bed. Initially we thought we would pile up the bed every night, but to be honest, when we are boating with just the two of us - we simply leave it down. You can get good quality 3' mattresses at very cheap price.
  22. That is the 'word' in Dursley - that it has been milked dry.
  23. As a local resident, I just noticed this on the front page of the local 'rag' http://www.gazetteseries.co.uk/news/11104579.Lister_Petter__has_let_staff_down_/ Anybody know any more?
  24. I would talk to Marine Engine Services - Chris Bennett (01895 236246) 01895 236246 01895 236246 01895 23624 01895 2362I'm sure that he can help and can probably source any spares you need
  25. I tried to talk to him on a number of occasions, as Archimedes and Marcellus were originally paired and I was hoping perhaps he had some old photos. I have to say that I always found him an arrogant tosser.
