I'm just wondering if there is anything comparable out there - in terms of spec and quality - other than Victron?
Also, I wonder if it would be better to go for completely separate charger(s) and inverter(s) ?
With regard to cooking - we've done a power audit for things like microwaves (1,000w) & kettles (3,000w) with one of those plug-in power usage monitors and although they use a lot of power it's for relatively short times, so the number of Ah used is relatively small. We have electric cooking at home but can't use the plug-in power monitor for this as it's hard wired. However, what we have done is found the power consumption of the fan oven from the spec (3,500w) and calculated full power until up to temperature and from that point on noted how often and for how long the thermostat calls for power to maintain temperature (assuming full power). Again, the total Ah (calculated @ 48v) to heat up an oven and then cook something for say 30 minutes is relatively small.
We typically wouldn't use more than two rings on a hob at a time. There's a youtube video of a guy using an induction hob to cook a meal in his campervan (actually there's videos of two different people doing this). He measured the electric consumed with a power monitor and it worked in a similar way to our fan oven test calculation - full power for a relatively short time to get up to temperature but very little to maintain temperature.
Taking everything that we know into account we know that our typical power usage per day will be significantly less than that required for cruising per day, and as we're likely to cruise for half a day maybe at a time (and then probably eat out at the end of a cruising day) we feel comfortable that based on our particular typical usage scenarios, it should all work out OK. And when there's an abnormally high electrical usage day and it's been raining non stop for a couple of days then the generator will have to earn its keep. I hereby swear not to run it before 10am or after 6.00pm. Unless we want your mooring ? ?
