Puff Along
    TORQUAY
  • Occupation
    Retired
  • Boat Name
    Puff Along
  • Boat Location
    Torquay
1,218 profile views
Puff Along's Achievements
Engager
Engager (3/12)
0
  1. I really don't know, They mentioned they where having problems the day before I left.Im back Sunday so will look into it a bit more.I only said to them they other day how sweet the engine sounded. Big Mouth I should have kept my trap sut!!!!!!
  2. I'm away at the moment, I haven't seen it. belongs to 2 ladies on our pontoon.They where told they need a new one...I was just trying to be helpful towards them.Facebook is good for some and not for others It's a great way to keep up with my Grandkids in Switzerland/America.
  3. As said a friend asked and I said someone will know. As said a friend asked and I said someone will know. It's a Thorney Croft T80 based on a Mitsubushi K4 D so Mr Darth is correct anyone know of a Heat Exchanger for one please?
  4. Looking for one for a friend in need!!! https://www.facebook.com/groups/boatscrapyarduk/permalink/1244958112809000/
  5. Hi i'm looking at running heat in to the cabin of the engine.only a small 2 person cabin engine water pump is with in 6' of cabin bulkhead. TBH I dont think it need a radiator just Copper tubing under the windows to clear misting etc and to give some much needed heat for a Old Man. Any diagrams to be view d or ides please.Thanks in Anticipation [Sea going Boat not Canal]
  6. Wow!!!!! I thought there would a list Like 1x1/2 ring / open ender 2 x 5/8'' 6 an 8 mill ring, socket set, 4 screwdrivers etc etc. Oh and a Hammer!!! But I will have a proper one and a rubber one!!! The only crows foot I have is around my eyes!!! I will have a sit down with a open tool box and work it out . Thanks anyway.
  7. Is there a list of must have/carry onboard tools required for every nut bolt on a 1.8.I need to shed weight from my over flowing tool box.
  8. Cheers John very little evidence of contamination in the 2 filters that where replaced.I will leave it alone for a couple of days ,Go back with a clear mind. Digest the thoughts of the members and work through it all again. But I will renew the fuel line from tank to engine.It is partly old rubber and copper.The mechanic has some Lloyd's Fuel Line in his garage so we will install that. Then start over. Thanks to everyone for their time and thoughts, I'm away for the month of May in the US as my Granddaughter is graduating from College. Might be able to get a couple of Steelhead an Coho Salmon as well!
  9. Can a send you a private message re engine came from,
    1. Tracy D'arth
      Tracy D'arth
      Please do. I will respect the confidentiality.
  10. How do I put on a video of the engine hu ting 1min30secs Would be a Pump Problem 🤔?
  11. Right here we go!!! After 6 hours of bleeding ,cutting out .We had to revert to the dreaded easy start to get her to fire up We believe the New Injection Pump is faulty!!! I say new it was brand new [not a recon ] 8 months ago and it has done less than 20 hrs .Well I say we it should be Martin he got it running for 15 mins .Then it started hunting rvs up/down exactly what it did 4 weeks ago 7 miles out at Sea and I limped it back into the bay ,where I fished all day and it started stopped all good but I never to it over 5 Knots..I did this as I have a outboard for such cases. I believed the fuel was compromised with diesel bug .{Bit I always use diesel bug inhibitor] I remembered on my last engine it had a bad case of bug and the engine note sounded exactly the same. When I changed the filters they where clean the separator bowl had less than .5''of water in it. We checked and checked again the for air one the connections,Bleeding the bleed screws and injectors as we went.Martin Heated the heater plugs direct from a 115 amp starting battery,You name it he did it. Once started it will run ok then hunt it may pick the revs /then decrease up 2/3 times then cut out completely .It may run hunt then cut out, it is Very Random. I will put on a video [it may take a minute as it is on my phone not on the lap top yet] where you can hear the different engine notes but I couldn't catch the actual stalling of the engine on video. PS the Batteries are NOT Leisure as I said they are starting Batteries by Hancook XV110 MF Made July 2018
