davidandheather
Everything posted by davidandheather
  1. HI I gave the bow thruster a good discharge a then tested the volts at the battery end while charging i was getting 14.05 volts the cable size is 90mm2 over 60 foot David
  2. We have a LEC 12v fridge been as good as gold the past 4 year David
  3. I did not build the boat we had it done for us so not sure of the size but they were very big from what i can remember, they looked like big armor cables i will have a look at the weekend. David
  4. Our bow thruster batteries are at the front of the boat and are charged by the 45 amp starter alternator via very thick cables. We have never yet had a problem using this system in 4 years not that we use the bow thruster much. David
  5. I don't hear very good things about the 3 coverage ? Hi Mark We have a 3 network modem seem to work ok all over the midlands, 10 times better than the vodaphone one we had before Cheers David
  7. Hi Bet thats not far of the mark depending on your mooring costs David
  9. And we still not got a tug never will at this rate just keep the one we got David
  13. Well you can be sure of one thing Dave will do a 1st class job David
  14. Cheaper to get your water out of the tap me thinks why take a chance with death David
  15. Found this on the web http://www.leptospirosis.org/ Filtration - does not work! Leptospira are incredibly small - they can pass through the pores in water filters, even those that claim to remove bacteria. They will pass easily through filters with a pore size of more than 0.2 micron, including membrane and charcoal types. High-pressure laboratory filters with a pore size of less than 0.1 micron will block them, but the typical hand-held water filters used by hikers, pool filters and the fitted cannisters used in some domestic kitchen applicanes are useless at removing leptospires - they are often used to separate leptospires from other bacteria when preparing samples for research, as the leptospires pass through but other bacteria don't! UV sterilisers These are also very effective against leptospira (and most other pathogens), and can be bought on all scales. Permanent systems for processing flowing water in a domestic house are available, but can be expensive and use electricity. Portable devices for camping and backpacking are also available, resembling a small flashlight or pen, and these can be used to sterilise a single cup of water - but need batteries. The advantage of using UV is that there are no chemicals involved, and the electricity required is less than for boiling the same volume. It does require the sample to be transparent though, so can't be used on things like milk Cheers David
  16. The garden shop near the marina in Crick always have house coal and some boiler nuts. if you go to the garage in Welford they have a good range, maybe expensive phunicite at 11 quid a bag David
  17. Just get one of these http://www.justoffbase.co.uk/Antifreeze-Te...34Pa38Ta38Oa3j0 David
  18. Hi ABNB have a 40 foot mooring at Crick Wharf they had a sign out when we past last week Crick Wharf West Haddon Road Crick Northants NN6 7XT Tel: 01788 822 115 Cheers David
  19. Hi Any decent machine shop will make you on one them in know time David
  20. Hi What you need to do is find a friend with a working boat load it up with the crap and hide it in the long grass on the Leicester section of the GU no one will ever know David
  21. Hi We had a problem with our Mastervolt inverter it was running on low volts and all the problem was a loose connection on the isolator switch maybe a good idea to check all the connections David
  22. Just found this http://www.thetford-europe.com/web/show/id=91559/langid=42 David
  23. Hi Ours has done the same this weekend and i can not see how it works David
  24. I will make the link work http://www.hybrid-marine.co.uk/index.html
