ditchcrawler
PatronDonate to Canal World
Everything posted by ditchcrawler
  1. In my case I went found it with sealant when I found it but it was the good coating of Sprayfoam om the inside that held it and kept things watertight
  2. @Tracy D'arth has away of doing it without a pressure gauge
  3. I don't think so, 18 tons pushing the fitting at 3 mph against the edge of a heavy duty( I don't know the name) steel pile something is going to give
  4. I have had two shear off when they have caught protruding steel work, thankfully not at the water line or below, This one was quite close down and I changed it out while in drydock
  5. A bit like the discount for an electric boat with a big diesel outboard that use to be moored there
  6. I went out to eat in Birmingham and they added12.5% to the bill as an entertainment surcharge, It would have been nice to have known that before I booked the table
  7. This is very true and well worth doing if any other welding is required That is also true as I have found out after fitting it, I really should change it next time I change the coolant
  8. I carry bolt croppers, may be I should up grade
  9. I think this is where the lady with the strange boat resided I was offered cheap diesel there. Its on FB with a video
  10. That doesn't look like a CRT lock
  11. With just connections at the top it must be impossible to change out the coolant without the use of a pump
  12. How much do heating engineers charge or worse get a plumber out
  13. If you take both the hoses off mine it soon empties, just take the bottom one of and it takes a little longer Maybe an opertunity to have a drain fitted at the bottom to make it easier to change the coolant every few years
  14. @Cwboatmover gets good reports if Matt is busy
  15. Its quite an area and trees don't seem to get much of a mention." recreational and tourism resource, a means of reducing over-supply of agricultural land, enhancing landscape and wildlife" and nowhere as 18% tree coverage House of Commons - The National Forest - Environment, Food and Rural Affairs Committee (parliament.uk)
  16. It rather depends on how well people labelled any photos they uploaded. location and historic i.e taken some years before the posted date, then the search function would easily find them.
  17. App, a thing that runs on a mobile phone or pad, I thought you had one of each DM, direct message as not enough posts to send one, I thought you were once a mod, sorry Forum moderator, so I thought you may have needed to know that. Info, Information software dev develops computer software BTW, By the Way.
  18. I think it needs a section for waterway photographs, not a thread, they get lost when they are not constantly in use.
  19. Actually it would be a fantastic resource that could be looked back on when things change, Just think if there were photos of say Birmingham there from just 20 years ago and in another 5 years it will look different again.
  20. To keep a boat compliant with the RCD/RCR if you do any work to it they , as I now understand it are not "the rules"
