Everything posted by PeterF
You would have expected that their map overlayed the colours in order of severity so closures on top of restrictions on top of advisories.
Barrowford is closed, I am waiting, perhaps it is hidden by the orange line.
Well, you can get out of Yorkshire but not far. Navigation Closure: Lock 45, Top Lock to Lock 51, Bottom Lock, Barrowford, Leeds & Liverpool Canal From Date: 24/04/2024 15:00 To Date: On-going Type: Navigation Closure Reason: Repair Starts at: Lock 45, Top Lock Ends at: Lock 51, Bottom Lock0 3/05/2024 12:17 Please be advised navigation remain closed at lock 51, Bottom Lock on the Leeds & Liverpool Canal due to a fault with the tail gate cill. Our local team have been to site and investigations are ongoing. To ensure the safety of our customers, padlocks have been placed on Lock 45, Top Lock and Lock 51, Bottom Lock to prevent access
Nationwide no longer have a physical base after leaving Great Haywood Marina as Lakeland took over the Marina and now run the marina brokerage themselves. Therefore they are selling boats from wherever the boat is located and as they accompany viewings this gives them additional time and staffing demands that marina based brokerages will not have. This may mean that they are culling the fender kickers more aggressively than other brokerages.
testing for gas leaks using a bubble tester
PeterF replied to paul wilderness's topic in Boat Equipment
Two narrow boats joined to change license to widebeam
PeterF replied to Shey's topic in General Boating
If one is empty and one is fully fitted how are you going to arrange for the welding to be done because as the empty boat will be riding much higher in the water. Then as you fit out the empty boat to be your studio it will want to sit lower. Weld them together as they currently sit and then live a lop sided life in the future or put them on the hsrd now, chock them how you would like them to end up, weld them up, refloat and live a lop sided life until you fit out the empty pan. -
I used HVO for a while, never got the tank to pure HVO, I reckon I got to about 85% HVO 15% red and had no issues with any of my Beta 43, Webasto Thermotop or Refleks stove.
https://bridgewatercanal.co.uk/boating/boating-services/
Building a Category C narrowboat!
PeterF replied to dreamboater's topic in Boat Building & Maintenance
£200k will not cover a quality bespoke narrowboat these days with a standard 40hp diesel engine and for this type of work you will not be talking to the budget builders or volume builders with standardised designs. When you come to sell it, who is going to values the extras. -
Presumably you have the CRT license / index number, pop it into this web page and it may have some details if you are lucky. i tried searching just on the name but there are 50 Badgers recorded. If you do find anything, come back and let us know what you find. https://canalplan.uk/boats/boats.php
I believe it was often called "gas liquor" or just "liquor" but "gas water" is descriptive. The generation of towns gas gave as byproducts a mixed organic liquid, "coal tar" and a mixed aqueous liquid "gas liquor" which contained a lot of ammonia along with other soluble compounds. This was used to generate ammonium compounds such as ammonium sulphate for use as a fertiliser. It could easily have contained cyanides as these are another nitrogen based compound like ammonia.
Many years ago I worked at a chemical manufacturer, Robinson Brothers ltd, that was based canal side just above Ryders Green locks. This was started up in the 1870s distilling coal tar as the Robinson family had a history owning gas works and managing gas works for councils. The company history states that it was served by narrowboats. They were involved with the other tar distillers, such as Midland Tar Distillers at Oldbury and Four Ashes. Some of the sites are still operating manufacturing speciality organic chemicals based on this heritage.
Posted on stoppages a few days ago 28/03/2024 11:18 Following on from our update in February, we would like to offer a further insight to the repair work at Lock 7, on the Marple Flight, Peak Forest Canal. Our contractors have finished installing the concrete piling, and over the coming weeks our engineers will conduct thorough integrity checks on each of the installed piles. Once completed, piling caps will be added, and a structural concrete will be poured as our teams work towards rebuilding the lock chamber. The repair is progressing well, and we anticipate the works to be completed on schedule, with navigation resuming on Friday 24 May.
Victron inverter/ batteries/ solar recommendations
PeterF replied to Silent Flight's topic in Boat Equipment
Putting a larger inverter in will probably need the DC cables increasing in size if you stayed at 12V, but in my view, the 3000 units is the max you should run at 12V, if you go to the 5000 unit then I would recommend 24V. If the boat is 12V now, then going 24V is going to probably need a dual voltage system plus some method of charging at 24V. The AC system will also need upgrading to handle higher current, new breakers, possibly new circuits. Regarding kit, I used to have an old boat with a mix of cheaper inverter, battery charger and solar control, it all worked OK. I had a new boat built a few years ago, all Victron, all works together seamlessly via the Cerbo GX with good monitoring and I have not regretted the extra expense of the Victron gear. -
If the inverter works OK and he wants to add solar then he just needs to get a Victron Smart MPPT solar controller which will connect to a phone via Bluetooth using the Victron Connect app. He could add a Bluetooth dongle on the inverter for basic monitoring on the inverter. Does he have a shunt and battery monitor to get a better idea of the state of the batteries. The Cerbo is a nice thing to have, I have one connecting my Victron gear together but not 100% necessary. -
Webasto manuals state 25% antifreeze.
As long as you do not reduce the flow too much and overheat the burner. However, it will still run at 80degC.
Have a read of the workshop manual which can be found at the link below. per the extract attached. 80degC is the target operation temperature at which the heater reduces the firing. As far as I know this is not user resettable. It might be with diagnostic kit.I https://www.webastomarine.co.uk/products/thermo-top-evo-5kw-narrowboat-kit
Poseidon's trident. 🫣 It appears to have a hook at the top of each upright so maybe ot is for putting a washing line on so you can put more stuff out on 3 lines.
Inverter motor washing machine, also called direct drive use a brushless motor to drive the drum directly without belts and the inverter function appears to mean a variable speed motor controller. If it will work depends more on the electronics in the speed controller.
Installation cooling fan above alternator
PeterF replied to Roberto Conigliaro's topic in Boat Equipment
If you want to run it off the ignition switch then you need a 12V relay, connect a lead from your ignition switch to the positive coil on the relay, negative coil goes to battery negative. Then connect from the battery positive to one side of the relay switch, the other side of the relay goes to positive on the fan then from the fan negative to battery negative. The fan could be wired to either engine battery or domestic battery, the relay keeps the fan circuit isolated from the engine electrics. Do not forget fuses. -
Am I being optimistic if I think (fantasize) that the significant costs of reservoir upgrades and repairs over the past 4+ years since he Todbrook incident should diminish over coming years, releasing (hopefully) more cash for routine navigation maintenance.
List of moorings https://bridgewatercanal.co.uk/boating/mooring/
And if you want to extend your stay on the Bridgewater beyond the free 7 + 3 days you can pay on line here. https://bridgewatercanal.co.uk/boating/pay-online/
Arco Zeus regulator - first impressions and a look inside
PeterF replied to cheesegas's topic in Boat Equipment
The problem with a lot of these drop ins with CAN Bus output is if you put several batteries in parallel, they still appear as two batteries, they do not aggregate themselves and present as a single battery to the control device which is a problem. The storage battery systems like Pylontech parallel up and appear as a single large battery. The Fogstsar Drift Pro says for connection to Victron Cerbo GX that you can connect one battery to the BMS Bus and one to the VE CAN Bus, so you have 2 individual batteries that can be monitored but only one can control the charging devices unless you add custom code to aggregate them as a single virtual battery.
