Days Won
2
Everything posted by Scholar Gypsy
Weekly stopover marina Nene and Middle Levels
Scholar Gypsy replied to Boondock's topic in General Boating
I would suggest b ) Oundle and then c) Fox's at March. Northampton to Peterborough would be a very long weekend trip, I think? -
15m of anchor chain but how much rope on the Thames
Scholar Gypsy replied to rubblequeen's topic in Boat Equipment
Please see latest safety bulletin issued by the PLA. Good photo! -
I had a good look at Aynho and Shipton weir when I was there a few days ago. I am pretty sure Aynho used to have two "normal" paddles on each gate. Now there is only one, with the second one replaced by the gadget you can see in this photo, which lets a small flow of water through each gate . Although visible, it is really quite a small flow, as otherwise one would not be able to get a level. I reckon the lengthsman puts a square section device through the hole - something like an Ouse key - to adjust the sluice that is under the water. I couldn't see anything equivalent at Shipton, which still has two normal paddles on the top gate. But then that has a rather larger fall anyway. Some good news is that overnight mooring is possible again at Shipton - next to the lock on the River Cherwell.
Going through Birmingham tomorrow how far do I need to go
Scholar Gypsy replied to rubblequeen's topic in General Boating
I have enjoyed several times mooring on the Winson Green loop, by the park that is just east of the prison. A bit shallow in patches. -
Good luck. On weather (the wind is what really matters), you may want to check the forecasts here or here. The consensus advice is that, in particular in the stretch between Limehouse and London Bridge, anything over 18mph starts to get a bit too exciting ...
Yes, but you left 3hrs 40mins before HW London Bridge (1215 BST) on a medium strength tide (6.5m), which is why you were flying, and got to Richmond before it opened. I was commenting on the original suggestion of leaving at 0930 this Saturday, only an hour before HWLB, and on a weak tide (6.1m). I still think that would not be a good idea at all.
It's 16 miles from Limehouse to Brentford, so (for most narrow boats) there is no way you will get there in two hours if you leave only an hour before HW London Bridge. The incoming tide will then be pretty weak, and will overtake you before long. You will then struggle to get to Brentford before the locks shut, or even worse find yourself going backwards ... I find it takes 2hrs 45mins to Brentford, with nice steady engine revs (in itself preferable to thrashing the engine), leaving 2.5 or 3hrs before HWLB. Good luck!
Bob High tide (edit: London Bridge) is 1030 (BST), so 0700 from Limehouse will be about right. If you go too much earlier you are likely to arrive at Brentford before the locks open (at 0930) - hardly a disaster! (edit: HW Brentford is at 1130). Enjoy!
Good lock instructions for people borrowing our boat
Scholar Gypsy replied to stort_mark's topic in General Boating
The earlier links to incidents on the Huddersfield contain the photos, but basically, if you are travelling downhill the top lock gate of the next lock is open the water level in the pound above the lock is low the bows of the boat go into the lock OK, but the stern runs aground on the cill (NBs will normally have a deeper draught at the stern than the bow) you then realise that the bottom gates of the lock are leaking badly, so the water level continues to drop the stern of the boat is then really stuck and the bows start to go down & down. all you can do is run back to the previous lock and open paddles at both ends of the lock, and hope the flow coming down is more than the leakage. and a similar thing can happen if you are going uphill, with the water level a bit lower so that the boat runs aground just as the bows leave the lock. In each case if less than half of the boat is aground and more than half is downstream of the cill, then as the water level drops the boat is at risk of tipping over / sinking. Going uphill, an alternative to point 4) is to make sure the rear fender is positioned between the bottom gates before opening the paddles. This will protect the gates from banging together when the paddles are opened. And on point 6) it is of course perfectly easy to jump across a 7' lock, avoiding lock gates completely. -
Coincidentally, I am doing exactly the same thing with my boat in a couple of weeks - and their first locks will be Hillmorton. In addition to all the good points raised above (BTW the hard copy and video versions of the handbook are here), I have told the lendee to tie up a few hundred yards before they get to the locks, and spend half an hour just watching other people work though. Cautionary tale on the point above about low water levels. and a more recent one here. Simon PS here is the extract from our boat handbook on the subject of locks.. There are comments elsewhere on the subject of fenders. · No running · Never leave a windlass in place after opening a paddle · Hold on tight when crossing a lock · Stand well back from the edge · Take care getting on and off the boat. Do not get on or off the boat when it is going past lock gates. · Keep the boat well clear of gates and (especially when going downhill) cills -
Twickenham Or Teddington Lock Can I...?
If anyone wants to see that stretch with no water in, here are the dates for the 2013 draw-offs: http://www.pla.co.uk/notice2mariners/pdf/M31_of_2013_-_Richmond_Lock___Weir_-_Draw-Off_2013.pdf -
Ditto our Mitsubishi: we added an extra filter between the tank and the pump (electric Vetus, with its own filter inside, so we now have three fuel filters..). I have been musing for a while about the practicality of installing a permanent fuel polishing circuit - for example a second pump pumping fuel through a filter (or maybe just a sedinenter) and then back into the other half of the tank (my tank is in two halves, with the filler on the left side and the fuel takeoff on the right). Not sure what a boat safety examiner would make of that...
Here are some articles on Wikipedia on gyrocompasses (NB not to be confused with gyroscopes, though the article does I think risk that confusion) and on fluxgate compasses. The latter still need correction to take account of the impact of the boat's hull on the local magnetic field. Another website I found noted that fluxgate compasses are often hidden away below decks, and this can be fun if eg tins of food are stored nearby and roll about in bad weather. Also be careful where you put your boombox or any other device with loudspeakers. And note that the deviation chart needs to be redone after a lightning strike (see other recent threads)....
Narrow Boat Hit By Trip Boat On Tidal Thames
Scholar Gypsy replied to magnetman's topic in General Boating
Worth noting that (according to the PLA's 2012 annual report) there were 38 "navigational incidents of note" last year. -
Narrow Boat And Rower In Collision On Thames
There are a number of handbooks and guides on the Environment Agency website: http://www.environment-agency.gov.uk/homeandleisure/recreation/133183.aspx The first one looks the most useful - see page 7 or so onwards. I don't think this is on the website that the Dog House is referring to. -
Blockage now cleared, according to email from Waterscape: "The obstruction which had been put in the canal has been removed by the third party and the canal is open to navigation."
The ecoblast air horn is effective - and no refills to worry about, as you just fill it up again using the small bicycle pump supplied. -
I think the point others are making - and I would agree - is that even with a standard NB steering position, out in the open, it is quite feasible to not be able to see a canoe, or a swimmer, ten feet (say) dead ahead of your bow. That's unlikely to be a problem in most circumstances, whether on a canal, river, or a tideway -- for example if one is catching up a slow canoe, then you will be able to see them before they disappear into the blind slot -- but I do believe it is a risk that needs to be kept in mind. -
It's a BBQ, for use after the annual St Pancras Easter Cruise to the Fox at Hanwell. -
Timings can also help - eg it is 0.8 nm from Tower Bridge to Wapping police station, and then the same distance again to Limehouse, Typically a bit under ten minutes for each segment. -
I agree with the previous posting by larryjc. I would also add that in my experience one needs to behave differently when meeting passenger trip boats - as noted earlier these regularly turn round, overtake, switch sides, stop at piers, break away from piers, tie up at their moorings, and so on. The safest plan (as Colregs say and as noted above) is for a narrowboater is to maintain a confident, steady course and speed, while not getting too close to the right hand bank (for example if you are too far to the right when going upstream through Tower Bridge then you cause problems for boats using Tower Pier). In my experience trip boats will navigate around you safely. large commercial vessels - eg a tug and three barges on its way to Wandsworth (photo below). Here they are taking a steady course and speed, and cannot slow down without losing control, and you should keep out of the way. So for example I was recently crewing on a narrowboat approaching Albert Bridge - where there is only one upstream arch. We saw a tug coming up from behind and the white isophase light flashing on the bridge. We did not fancy going through the bridge at the same time as the tug, so I got on the radio and asked if the tug wanted to go through first. If he had said yes we would have turned around to starboard (4+1 blast), and stemmed the tide until he had gone past me (passing starboard to starboard) before turning again to continue upstream. As it happens he said no, as he was slowing down anyway before stopping at Battersea. -
An opportunity for another plug for my portable fixed set: a second hand fixed set from Ebay, speaker and aerial cost less than the handheld! It has been used on three different boats so far this year (Limehouse to Brentford, Limehouse to Teddington, Limehouse to Gravesend & back), and is on the lookout for more boats to travel on. It can pick up London VTS in Reading (though they couldn't hear me...) -
I find it very handy to have a thin line running along the roof from the stern, joined to the bow rope. Then, for example, when going uphill I can climb up a ladder holding (eg) stern rope and said thin line, tie off stern, and then walk to bows and pull the bow rope up. Much easier to handle than a 25m full size rope.
I would invest in a cheap multimeter that will tell you which is +ve. When we had our boat stretched (the second time) the extension to the cable to the horn had the wires connected back to front. It took me a while to work this out, when I next replaced the horn - it mattered as the chassis of the horn was bolted to the steelwork, and so the negative wire had to go to the chassis as well.
I think we are confusing two scenarios here: * a controlled stop, where you would turn into the tide/current, bring the boat to a stop, lower the anchor, and then back away in the way you describe. Most narrow boats would struggle to do that (or to moor to the bank safely) in a 7 knot current - see earlier posts * a sudden engine failure while you are doing 7 knots over the ground going though Cannon St railway bridge (which is not unusual). Unless there is another boat very close to you who can get a line to you, you have to chuck the anchor over the side, keep all limbs out of the way, and brace for a rather sudden stop....
