Thought this might be the right place for this.
Lynn does NOT like stuff strewn on the boat roof LOL even the solar panels, but I'm getting away with that as they allow for a hair drier LOL
Anyway I noted we had lots of items that were quite long and thinish, and noted many plumbers vans with tubes for storing & transporting pipework.
So I thought of something similar. Finding a decent size tube though is tricky. In the end I went for 160mm plastic Terracotta drainage pipe, this generally comes in 100mm / 4" for regular household drainage. As luck would have it I visited a local builders merchant and they had a load of 3m lengths of the stuff. Some of the pipes had turned Grey and I managed to get a good discount and paid just over £20 each inc v.a.t
Lynn didn't like the colour though so they were painted Grey as we thought the plastic might go wobbly if in a dark colour in the heat.
Anyway pipes back at the depot and work begins.
We had half a sheet of 12mm ply left over from the gang planks project, so I cut to shape 4 frames for the tubes then bonded them together with Gorilla Glue to make a pair of 24mm thick frames. Each frame needed 5 holes, 4 for the tubes and a bigger central hole to hold The Whirly gig washing line which is a bigger diameter than the tubes.
These were all routed out with a small Bosch router and painted with several coats of decking stain left over from the gang plank project. The routered circular off cuts were used as stop ends and glued inside the end of each tube. Proper end caps will be purchased for the removable fronts.
With pipes now painted and frame stands ready it was back to the boat to assemble. All went together eventually, a couple of holes a bit tight, we'll just need to seal around all the frame holes & pipes with some clear Stixal to completely weatherproof the ply. The front caps are just standard stop ends with the inner edge polished so it slips on and off the pipe easily. The S/S knobs are just some stuff left over from the boat build.
The tubes hold as follows.
Whirly gig drier
9 f/t span sun umbrella.
Telescopic aerial pole.
2 fishing rods & reels
broom & mop handles.
Large Fishing Keep Net
Costs
Tubes £41.00
End caps £20 inc delivery
1/2 sheet Ext ply £15.00
Basically everything else was in the workshop so total cost just under £80.00
