smileypete Posted December 21, 2012 Report Share Posted December 21, 2012 Only single speed and 10.8V so more for light use, but may be handy on a boat: http://www.hotukdeals.com/deals/sparky-10-8v-li-ion-drill-driver-25pc-accessory-kit-a-cantilever-case-screwfix-1419721 cheers, Pete. ~smpt~ Link to comment Share on other sites More sharing options...
Justme Posted December 21, 2012 Report Share Posted December 21, 2012 Ad says variable speed. Link to comment Share on other sites More sharing options...
Rich Posted December 21, 2012 Report Share Posted December 21, 2012 (edited) Challenge Xtreme Lithium Ion Drill Driver - 10.8V. 711/4274 @ 29.99 UKP. The li-on bit is good. Bought one yesterday and seems good for the price. Richard ETA-should have mentioned, from Argos Edited December 21, 2012 by Rich Link to comment Share on other sites More sharing options...
nbfiresprite Posted December 21, 2012 Report Share Posted December 21, 2012 Challenge Xtreme Lithium Ion Drill Driver - 10.8V. 711/4274 @ 29.99 UKP. The li-on bit is good. Bought one yesterday and seems good for the price. Richard ETA-should have mentioned, from Argos Ive been using this one for the last few months. Far better than the old 14v ni-cad one it replaced. Comes with a smart charger. The only down side is that you can not get spare battery's. Link to comment Share on other sites More sharing options...
smileypete Posted December 21, 2012 Author Report Share Posted December 21, 2012 Ad says variable speed. Sorry, meant single gear. 2 batts though. cheers, Pete. ~smpt~ Link to comment Share on other sites More sharing options...
Keeping Up Posted December 21, 2012 Report Share Posted December 21, 2012 I hope it's good, I just ordered one because my old drill's batteries are shot after 5 years of abuse and I can't find replacements for them Link to comment Share on other sites More sharing options...
smileypete Posted December 21, 2012 Author Report Share Posted December 21, 2012 I hope it's good, I just ordered one because my old drill's batteries are shot after 5 years of abuse and I can't find replacements for them If it's only a few cells down then it might be worth a go at recelling them: http://www.canalworld.net/forums/index.php?showtopic=45473&view=findpost&p=902461 The one above still holds a good charge from back in July I've gone for this Sparky deal but if I miss using 'The Beast' I'll pass it on to someone. cheers, Pete. ~smpt~ Link to comment Share on other sites More sharing options...
Keeping Up Posted December 21, 2012 Report Share Posted December 21, 2012 If it's only a few cells down then it might be worth a go at recelling them: http://www.canalworl...ndpost&p=902461 The one above still holds a good charge from back in July I've gone for this Sparky deal but if I miss using 'The Beast' I'll pass it on to someone. cheers, Pete. ~smpt~ Good idea, maybe the two batteries have enough good cells between them to make one good battery. Once I've got the new one I'll have a play with the old one - after all, there's nothing to lose. Link to comment Share on other sites More sharing options...
Mike Tee Posted December 21, 2012 Report Share Posted December 21, 2012 (edited) I hope it's good, I just ordered one because my old drill's batteries are shot after 5 years of abuse and I can't find replacements for them Open them up, (carefully,) you may find you can replace the innards. Some you can, others you can't, but if they are totally shot, nothing to lose. Just read Smileys post - explains it a bit better than me!! Edited December 21, 2012 by Mike Tee Link to comment Share on other sites More sharing options...
Guest Posted December 21, 2012 Report Share Posted December 21, 2012 These "12V or less" drills are great, because when the battery does die, you can solder a decent sized flex in and run off the boat 12V supply. I have had one such on the boat for ages, that would oherwise have been skipped. Link to comment Share on other sites More sharing options...
mango Posted December 22, 2012 Report Share Posted December 22, 2012 These "12V or less" drills are great, because when the battery does die, you can solder a decent sized flex in and run off the boat 12V supply. I have had one such on the boat for ages, that would oherwise have been skipped. I have done this with a 9.6 volt cordless tyre pump, using a light cable to provide voltage drop. It works fine because the load is constant and since the cable is extended it gets barely warm. Link to comment Share on other sites More sharing options...
Guest Posted December 27, 2012 Report Share Posted December 27, 2012 I have done this with a 9.6 volt cordless tyre pump, using a light cable to provide voltage drop. It works fine because the load is constant and since the cable is extended it gets barely warm. Neat idea building some volt drop via the flex I suggested this for halogen lights that kept blowing (12V domestic ones) some years ago and got flamed alive! There are often 12V power tools in the skip at our local recycling centre, but SWMBO won't let me near it. Link to comment Share on other sites More sharing options...
smileypete Posted December 30, 2012 Author Report Share Posted December 30, 2012 Picked mine up today from Screwfix, well pleased with it, feels solidly made Apparently Sparky tools are made in Bulgaria, well they don't look chinese cheers, Pete. ~smpt~ Link to comment Share on other sites More sharing options...
Keeping Up Posted December 30, 2012 Report Share Posted December 30, 2012 My first reaction, I'm pleased with mine too. I particularly like the LED work-light, and the rotating sleeve on the scerewdriver-bit holder. Link to comment Share on other sites More sharing options...
John Holden Posted December 30, 2012 Report Share Posted December 30, 2012 I keep reading this thread title as "cheap thrill alert" I'll go away now. Link to comment Share on other sites More sharing options...
