Guest Posted August 12, 2005 Report Share Posted August 12, 2005 (edited) If, when solo handling, it is accepted that the handler should take a centre line ashore when working through a lock – how do you cope when the lock entrance is covered by a bridge? If you take a line ashore the bridge prevents you from hauling the boat into the lock. If you allow the boat to motor into the lock under idling revs, you are left without a line to the boat. Seems to me that the only option is to use that lovely iron ladder with it’s wet, slippery, slimy rungs. How do you other solo handlers cope with covered entrances? Peter Deptmore Lock, Staffs & Worcs. Edited August 12, 2005 by Guest Link to comment Share on other sites More sharing options...
David Schweizer Posted August 12, 2005 Report Share Posted August 12, 2005 If, when solo handling, it is accepted that the handler should take a centre line ashore when working through a lock – how do you cope when the lock entrance is covered by a bridge?If you take a line ashore the bridge prevents you from hauling the boat into the lock. If you allow the boat to motor into the lock under idling revs, you are left without a line to the boat. Seems to me that the only option is to use that lovely iron ladder with it’s wet, slippery, slimy rungs. How do you other solo handlers cope with covered entrances? Peter Deptmore Lock, Staffs & Worcs. 27800[/snapback] You have already answered your own question, you climb up the ladder with windlass and end of rope in your hand. Except for the odd lock when there is no ladder which leaves you the gate!! Believe me, I have done that in the past Link to comment Share on other sites More sharing options...
Guest Posted August 12, 2005 Report Share Posted August 12, 2005 David Think I'll put both thro my belt and keep two hands for those wet rungs! Peter Link to comment Share on other sites More sharing options...
maffi mushkila Posted August 12, 2005 Report Share Posted August 12, 2005 (edited) Somebody here, a while ago, told of a guy that used to swing the rope under the bridge while standing on it and catch it as it flicked up the other side. Would take a bit of practice me thinks. Edited August 12, 2005 by maffi mushkila Link to comment Share on other sites More sharing options...
Guest Posted August 12, 2005 Report Share Posted August 12, 2005 Maffi It would at Penkridge Lock on the S&W - it's a road bridge Although thinking about it, you'll probably say "no problem" !! Link to comment Share on other sites More sharing options...
John Orentas Posted August 13, 2005 Report Share Posted August 13, 2005 (edited) Some years ago I spent the night in Ellesmere Port boat museum prior to cruising the Manchester Ship Canal the following day as part of a convoy. A couple of the staff spent some of the evening moving the MSC dumb barge Bigmere across the complex to the big lock to be ready for leaving early in the morning. I had always wondered what the purpose the winch is which was always fitted on these barges, well those two chaps moved that big heavy craft through several locks and low bridges, squeezing past all kinds of obstacles one of them stayed on the bank tying the line to bollards along the route as the other operated the winch, it all looked very easy. Several times it was necessary to pass the line below low bridges usually at the tail of the locks, the guy casually put half a dozen coils on the line while standing on the bridge and then threw it down-wards, having done so he turned around and approached the other parapet were he was met by the line coming up from below, catching it he carried on to the next bollard. All very impressive. I have tried it myself since, it is not easy. Edited August 13, 2005 by John Orentas Link to comment Share on other sites More sharing options...
bottle Posted August 13, 2005 Report Share Posted August 13, 2005 It's been done on the telly! It was in one of the early "Waterworlds" the lock keeper did it at one of the crossover bridges at Foxton, It looked easy ( always does when an expert does it) Link to comment Share on other sites More sharing options...
Carrie Posted August 13, 2005 Report Share Posted August 13, 2005 Hi. There's also taking a boat hook ashore with you and hooking the vertical rope through from the other side of the bridge. Think I read that in 'Going Solo' by Colin Edmondson. I haven't tried it myself, but climb the slimy ladder instead - yuk! Link to comment Share on other sites More sharing options...
Sam Posted August 15, 2005 Report Share Posted August 15, 2005 You would need some could hookingship (what?? ) and a long hook for that though! Sam Link to comment Share on other sites More sharing options...
Guest Posted August 21, 2005 Report Share Posted August 21, 2005 I reckon if I coiled and looped the centre line over the end of the tiller, I could snag it with my boat hook (it's a lightweight telescopic one for river use, retrieving lines from the water etc). I'll certainly try it Carrie, but only when I have my OCM on board to rescue the situation! Peter Link to comment Share on other sites More sharing options...
DHutch Posted August 29, 2005 Report Share Posted August 29, 2005 When im entering a lock 'single handed' (after my grandad has opened the gates and walked on to the next lock) i drive in, knock the engine off, and take the center rope ashore with me. Then if im going down in a narrowlock, i just leave the rope on the ground as i operate the lock, just for good mesure, then i open the gates, climb down the ladder, and go to next lock. Going up (in a narrow lock) i climb up the ladder with the center line, tie the center line around the bottom gate beam and open the first ground paddle, then i run back to supervise the rope fo a while, tigtening if needed it as the boat rises, then i raise the 2nd paddle a bit later, al depeding on the lock in question, and how strong the currents are etc. Daniel Link to comment Share on other sites More sharing options...
Big COL Posted August 30, 2005 Report Share Posted August 30, 2005 (edited) Then if im going down in a narrowlock, i just leave the rope on the ground as i operate the lock, just for good mesure, then i open the gates, climb down the ladder, and go to next lock. Ah! Dan you'r the one that never closes gates then. Edited August 30, 2005 by Big COL Link to comment Share on other sites More sharing options...
DHutch Posted August 30, 2005 Report Share Posted August 30, 2005 Ah! Dan you'r the one that never closes gates then. We always close the gates behind us, but when theres two of us, the 2nd person closes the gate, leaving the helm to keep the boat moving. Daniel Link to comment Share on other sites More sharing options...
onionbargee Posted October 14, 2005 Report Share Posted October 14, 2005 Of course, you are not required, or supposed to close gates leaving locks, theres no mention of it in B.W bylaws, it's a myth, and it was not done untill B.W started the practice to cover lack of maintainance some time in the 60's or 70's. It makes extra work for boats in both directions. Link to comment Share on other sites More sharing options...
alan_fincher Posted October 14, 2005 Report Share Posted October 14, 2005 (edited) It makes extra work for boats in both directions. Only if the next boat along is going in the opposite direction, of course If you are following someone, and turn up with the lock against you, it's actually quite nice not to have to go and shut the gates - particularly if it's a broad lock. Actually, several of the locks on the Grand Union main line near our base require that the lock is always left empty, (or at least emptying...) That's because if you don't the basements of the lockside cottages fill with water - I know this because my brother used to be a local lengthman for a while, and hence lived in one, and sometimes had to don wellies indoors. If you are "going up", it's actually quite a pain to have to get the top gates shut, and go and draw a paddle before moving on. Edited October 14, 2005 by alan_fincher Link to comment Share on other sites More sharing options...
Breals Posted October 14, 2005 Report Share Posted October 14, 2005 (edited) I'm new to this really, but I have been closing gates after me, because I thought it was expected of me (and there were some BW notices to the effect). But its an annoyance when you are single handed, meaning you have to tie up the boat twice. Anyone following you would have to jump off and do the paddles anyway, so its not a major inconvenience for them to also close the gates. Plus I have moored up to close the gates, only to see them drift open again once I have continued on my way... I'll continue to close the gates as I go, but I can see myself easing off on this particular bit of etiquette... Edited October 14, 2005 by Breals Link to comment Share on other sites More sharing options...
matt Posted October 15, 2005 Report Share Posted October 15, 2005 When I am on my own (or if my misses is busy with the kids - 5mths and 2yrs) I try to close gates where it's practical without roping up again. E.g. if going down and there are steps, I almost always close going up. One of the biggest problems is sluices, you can't control the boat on the exit and have to keep going, on a flight it's okay as you can walk back ... I always make an effort to close both sets of gates on the ends of long pounds - I wouldn't want to be responsible if there was a problem. Middlewich is a pain for this as the locks are really deep and slimey, I pull the boat out and jump on, the ladders are minging. However, if you do leave them open - expect a mouthful from someone behind later in the day or expect people to look at you in pity like you have no partner and no mates - I often get 'shame, are you all on your own?' Link to comment Share on other sites More sharing options...
fender. Posted October 15, 2005 Report Share Posted October 15, 2005 (edited) When I am on my own (or if my misses is busy with the kids - 5mths and 2yrs) I try to close gates where it's practical without roping up again. E.g. if going down and there are steps, I almost always close going up. One of the biggest problems is sluices, you can't control the boat on the exit and have to keep going, on a flight it's okay as you can walk back ... I always make an effort to close both sets of gates on the ends of long pounds - I wouldn't want to be responsible if there was a problem. Middlewich is a pain for this as the locks are really deep and slimey, I pull the boat out and jump on, the ladders are minging. However, if you do leave them open - expect a mouthful from someone behind later in the day or expect people to look at you in pity like you have no partner and no mates - I often get 'shame, are you all on your own?' Yesterday I had eight broad locks all gates left wide open by a crewed boat whose identity I dont know, except a sketchy description by some electrical workers of a boat with several crew on board passing by half an hour earlier. Of course I had to close all gates before I could use the locks. i am of the opinion that this closing of gates is a myth because when people like myself do close all the gates and then find crewed boats aint even arsed about shutting any of them why should I bother. Thats it I am not bothering anymore. BW are defintely increasing the licences - so I'll consider it the job of their staff to close them for me if I am single handed. Edited October 15, 2005 by fender. Link to comment Share on other sites More sharing options...
David Schweizer Posted October 15, 2005 Report Share Posted October 15, 2005 Why do people get into a lather about whether the gates are left open or shut? It's swings and roundabouts. You have to tie up if the gates are closed irrespective of whether the lock is with you or not, in order to open them. Usually the lock is only partially full or empty so paddles have to be raised, all taking time etc. At least if the lock is with you and the gates are open you can go straight in without tying up and opening gates. Yes it is a pest if the lock is against you, and you have to walk round the lock to close gates, but on balance less time is used if gates are always left open, That is why the working Boatmen always left them open. Because you are treated like a criminal by some Johnie come lately boaters these days, I now leave gates closed, but I would love to return to the former practice of Gates open, paddles up. Link to comment Share on other sites More sharing options...
Big John Posted October 16, 2005 Report Share Posted October 16, 2005 If, when solo handling, it is accepted that the handler should take a centre line ashore when working through a lock – how do you cope when the lock entrance is covered by a bridge? I don't accept that the handler should take a centre line ashore in a narrow lock, going up hill. With practice it's possible to let the boat drift into the lock coming to rest gently against the cill, having stepped off the stern at the bottom of the lock. If tickover is really low, I should think she can go in under gentle power, but careful control of the paddles (keeping an eye out for potential "help") can keep control of her. Link to comment Share on other sites More sharing options...
matt Posted October 16, 2005 Report Share Posted October 16, 2005 If it speeds up too much you can also slow the boat down using the gate (if you are gentle). This is apparently how solo lockers have always done it (I got a long lesson once of an old boater in locking). If I go up I leave it in gear, going down I now tie the boat to the bottom gate so it stays off the cill, it's easy once you get used to how much slack to leave for lock depth - I open one paddle if I'm on a flight then walk down and set the next lock and open the gate, then pull the boat out, jump on and go straight into the next lock, walking back sometimes to close the previous gates Link to comment Share on other sites More sharing options...
onionbargee Posted October 17, 2005 Report Share Posted October 17, 2005 (edited) I knew that post would put the cat in with the pidgeons ! It is true what david sais, in the working boat times gates were left open, and paddles up, because in the long run that is the most efficient way of working, it takes alot of thinking about, uphill, down hill, boats following, approaching, ect, ect, but that is the way they work, full stop. Closing the gates throws a spanner in the works, and causes extra work for everyone. If you close gates, a boat approaching will have to stop, tie up, to open them, and possibly, usually, draw a paddle as well, when they could have gone straight in, that's two or three extra bits of work, a boat following will have to empty the lock anyway, giving the top gates a shove is no big deal, but it ensures there are empty locks, with gates open for everyone, and you save work. Edited October 17, 2005 by onionbargee Link to comment Share on other sites More sharing options...
Yamanx Posted October 17, 2005 Report Share Posted October 17, 2005 Yes, but they leak. If the upper gate leaks quite badly and the gates are left open too much water is lost. Although I am guilty of leaving them open, especially when going down (Up is not too much of a problem to close them) and there is nowhere to tie up, and the water is too shallow at the edges so I end up beaching the boat six foot from the edge and getting stuck for ages, and end up sweating and swearing with a pole, and then leave the blimin gates open anyhow as I couldnt get off the boat. Just leave 'em. Link to comment Share on other sites More sharing options...
Guest Posted October 18, 2005 Report Share Posted October 18, 2005 (edited) I don't accept that the handler should take a centre line ashore in a narrow lock, going up hill. With practice it's possible to let the boat drift into the lock coming to rest gently against the cill, having stepped off the stern at the bottom of the lock. If tickover is really low, I should think she can go in under gentle power, but careful control of the paddles (keeping an eye out for potential "help") can keep control of her. I'm only 30' long and 9tonnes displacement so she moves about quite alarmingly if left without any centre line. 60' and 17tonnes will not be quite so quick to to go charging up the lock with the surge from the paddles - and a 60 footer has only got a max of 12' to go anyway. If I'm at the bottom going up and the surge catches her without a line, she's going at a hell of a rate by the time she hits the top gate, 42' later! Peter Edited October 18, 2005 by Guest Link to comment Share on other sites More sharing options...
