jenevers Posted August 21, 2018 Report Share Posted August 21, 2018 Can tar varnish be applied over a previously painted metal surface? Link to comment Share on other sites More sharing options...
BEngo Posted August 21, 2018 Report Share Posted August 21, 2018 Yes. Depending on the prior paint the results may be interesting. Patch test first. N Link to comment Share on other sites More sharing options...
jenevers Posted August 21, 2018 Author Report Share Posted August 21, 2018 4 minutes ago, BEngo said: Yes. Depending on the prior paint the results may be interesting. Patch test first. N It’s Leyland exterior gloss, which I’ll scuff down. I thought it might be a complete “no-no”, like putting comastic over bitumen (or is it vice versa?). It’s to cover up a cream stripe Below the gunwhale, so that it blends in with the rest of the hull. I’ll do a test patch first. I could use black gloss paint but it wouldn’t blend in as well. Link to comment Share on other sites More sharing options...
David Mack Posted August 22, 2018 Report Share Posted August 22, 2018 Beware that if you do this, then the first scratch you get will show the cream through. We had this on Fulbourne until we bit the bullet and cleaned the whole section between the top guard and gunwale back to bare metal. Link to comment Share on other sites More sharing options...
jenevers Posted August 30, 2018 Author Report Share Posted August 30, 2018 On 22/08/2018 at 13:58, David Mack said: Beware that if you do this, then the first scratch you get will show the cream through. We had this on Fulbourne until we bit the bullet and cleaned the whole section between the top guard and gunwale back to bare metal. Yes. I'll just slap a bit more tar varnish on when that happens ? On 22/08/2018 at 13:58, David Mack said: Beware that if you do this, then the first scratch you get will show the cream through. We had this on Fulbourne until we bit the bullet and cleaned the whole section between the top guard and gunwale back to bare metal. Link to comment Share on other sites More sharing options...
