ditchcrawler Posted July 29, 2018 Report Share Posted July 29, 2018 22 hours ago, Tony Brooks said: Who said it would not. OK if its fixed and there are no signs of heat damage. Its the portable gas haters that the OP asked about. You then brought up catalytic heaters. Is it still acceptable to fit them? Link to comment Share on other sites More sharing options...
Alan de Enfield Posted July 29, 2018 Report Share Posted July 29, 2018 34 minutes ago, ditchcrawler said: Is it still acceptable to fit them? I must admit I was under the impression that had 'grandfather rights'. Link to comment Share on other sites More sharing options...
David Mack Posted July 30, 2018 Report Share Posted July 30, 2018 13 hours ago, MartynG said: GRP being combustible material sometimes with the roof deck possibly having a core of wood and heat from the chimney being potentially very high . Not only that sufficient air supply required to avoid carbon monoxide poisoning. On that basis a wooden boat, or a steel boat with a wooden cabin, shouldn't have a solid fuel stove. Yet lots do. And the CO point applies to all boats, whatever they are made of. Link to comment Share on other sites More sharing options...
ditchcrawler Posted July 30, 2018 Report Share Posted July 30, 2018 20 hours ago, MartynG said: GRP being combustible material sometimes with the roof deck possibly having a core of wood and heat from the chimney being potentially very high . Not only that sufficient air supply required to avoid carbon monoxide poisoning. A diesel heater on the other hand being made specifically for the purpose with the exhaust designed to operate at a tolerable temperature. Surly a GRP boat has the same requirements for ventilation as a steel one to mitigate the danger of CO poisoning Link to comment Share on other sites More sharing options...
Alan de Enfield Posted July 30, 2018 Report Share Posted July 30, 2018 16 minutes ago, ditchcrawler said: Surly a GRP boat has the same requirements for ventilation as a steel one to mitigate the danger of CO poisoning But it is only advisory on any boat. Sea 'capable' boats can even have it all closed up - we have a sign over the hob saying 'open vent when cooking' (hidden behind the kettle) BSS 8.9.2 Are warning notices displayed on sea‐going boats with closable ventilators? On all seagoing boats with closable ventilators a warning notice must displayed on or near all non‐room‐sealed fuel burning appliances. The warning notice must read: ‘WARNING – Open ventilator(s) before use’, or equivalent wording. Link to comment Share on other sites More sharing options...
