Chas78
Toilet flush valve thingy?
Hi All,
I have just re-positioned my pump out toilet but after disturbing the pipework now find the flush vale thingy is leaking it seems through the bottom outlet pipe whatever that is for??? should there be a pipe coming from the other outlet pipe can you buy or recon this unit any suggestions as always very much appreciated ;)
Share this post
Anti siphon valve. someone else had the same problem posted on here of Facebook. you can get new ones from Lee Sanitation
Share this post
Could you be more specific about where the leak is coming from? Is it from the blue tube (which looks like an inlet from the arrows)? If you have disturbed the pipework - is the leak just from  the joint to the tank (is that a tank?). What did you dismantle?
Share this post
No Dr Bob its definitely coming from the top of the valve nothing dismantled the picture was taken after i removed the valve for inspection into the leak its just sitting on my sink drainer ;) thanks for the link Brian :cheers:
Share this post
 Does it only leak when laying down? that doesnt surprise me as its an anti siphon valve to let air in, it is not meant to work laying down but standing up straight. Put it back on and see if it leaks, it probably wont. :D
Share this post
It leaked when in situ ie when vertical i never tested it horizontal it was lying on my sink drainer for picture purposes only i have now acquired a nearly new valve so all good no leaks .
Share this post
Thee has been a spate of these leaking. I wonder if its limes cale and if letting it sit for a day or so submerged in lime scale remover might work.
Share this post
Good idea Tony i never thought of that ;) i did think if it could just be replaced buy an anti drain back vale of some sort instead of this over complicated set up :mellow:
Share this post
Me too. If a double check valve is good enough for UK domestic use why not on a boat?
Share this post
I wonder what the collective noun is for multiple toilet flush valve thingies?
Thee has been a spate of these leaking. .
Share this post
