Movin' on Posted February 28, 2018 Report Share Posted February 28, 2018 Hi, I have a pre soft shift PRM500 attached to my 2LW the bits to modify/change in situ are £275 - what experience do others have with this set up - is it worth doing?? The cheaper option is to take the box out then a rebuild and change is £150 but I don't want the hassle unless the box has an issue (not expected) which I guess I'll find out when I start using her next month. Or I might just park the idea and remove/change next winter. Link to comment Share on other sites More sharing options...
steamraiser2 Posted February 28, 2018 Report Share Posted February 28, 2018 It is really a matter of personal preference. If you are using conventional controls it is probably fine as it is. If the intent is to use Morse controls I would go for the soft shift conversion. Either way the PRM500 is a really good gearbox. Overkill for a 2LW though unless the output ratio was not available in the PRM260 range Link to comment Share on other sites More sharing options...
Movin' on Posted February 28, 2018 Author Report Share Posted February 28, 2018 (edited) 58 minutes ago, steamraiser2 said: It is really a matter of personal preference. If you are using conventional controls it is probably fine as it is. If the intent is to use Morse controls I would go for the soft shift conversion. Either way the PRM500 is a really good gearbox. Overkill for a 2LW though unless the output ratio was not available in the PRM260 range Conventional controls - I think I will suck it and see - on a past boat Perkins D3 and PRM 260 I did the conversion but I was never completely convinced it made that much difference - I don't like clunks but if as I'm advised by PRM its just the lack of pressure relief then I'll live with it . After all its not like I do Morse style fast shifts! Thanks Edited February 28, 2018 by Halsey Link to comment Share on other sites More sharing options...
PeterG Posted February 28, 2018 Report Share Posted February 28, 2018 Yes I would agree the PRM500 is more than good enough for a 2LW. Personally I would leave it as it is and save the money. 1 Link to comment Share on other sites More sharing options...
