Hawkmoth Posted November 11, 2016 Report Share Posted November 11, 2016 So its your fault the rest of us are now having to suffer under propping! Mea culpa! Link to comment Share on other sites More sharing options...
Bee Posted November 11, 2016 Report Share Posted November 11, 2016 OK, why don't we use controllable pitch props, just pull a lever and the blades rotate on the hub and voila, boat goes backwards? Doesn't it? Its not the same as putting a handed prop on backwards, or is it? Chuck the gearbox away and all that stuff, just have a reduction gear. Link to comment Share on other sites More sharing options...
BEngo Posted November 11, 2016 Report Share Posted November 11, 2016 OK, why don't we use controllable pitch props, just pull a lever and the blades rotate on the hub and voila, boat goes backwards? Doesn't it? Its not the same as putting a handed prop on backwards, or is it? Chuck the gearbox away and all that stuff, just have a reduction gear. They are available. They are complicated. They are less efficient than fixed blade propellors overall. They are less robust. They are expensive. N Link to comment Share on other sites More sharing options...
Bee Posted November 11, 2016 Report Share Posted November 11, 2016 They are available. They are complicated. They are less efficient than fixed blade propellors overall. They are less robust. They are expensive. N Ah, its the 'expensive' bit that finishes it for me. Link to comment Share on other sites More sharing options...
Jrtm Posted November 11, 2016 Report Share Posted November 11, 2016 Well both actually but normally more pronounced in reverse I think In that case yes I get this very badly! Add 9/10 its the wrong way for what I'm doing Link to comment Share on other sites More sharing options...
