I am pretty sure I need to replace the crank shaft oil seal. I was wondering whether anyone had done this on a BMC 1.5 before and what sort of things I should be careful about (if any!).
Thank you!
Access, damaging the rubber damper in the pulley if you have to use force, the seal comes out of the inside of the timing cover so you need a gasket, check the timing chain while you are in there, breaking fingernails
Richard
I did think I would have to lift the engine or cut an access hole in the bulk head....
is it a pig of a job?
It's a pig of a job if you cannot get at the front of the engine like on my boat. If your engine is out and accessable then it is a straight forward (mostly) job. I have done one on an engine that I have sitting on a bench in my garage and it was reasonably simple. If I had to replace the seal on my boat engine then I would have to take the engine out or cut a hole through my shower cubical wall and through the metal bulk head behind that. Not something I would relish doing either way.
If you get away without having to use a puller, you would need at least five inches of clearance. You might manage with a little less. Otherwise, no not too bad a job
Richard
This is Bones we're talking about here........
............... of course it will be a pig of a job ;)
................. shall I put A&E on alert?
I have often wondered what would happen if I got stuck in an engine bay - perhaps we are about to find out
Richard
Richard
I think you'll find that young Bones has been there and got the Tee shirt, but will almost certainly return there
Edited by Proper Job
Thank you everyone.
I have 5 inches spare - so that's a good sign.
I have been for a class on how to do it from someone who has done it.
I have PJ's number on speed dial.
what could possibly go wrong!
OK...camera to the ready. I ordered the bits, but one of them was a bit of a surprise - not quite the shape I was expecting....but we shall see.
