Aylesbury Arm Closed?
BEngo
The balance beam one one of the gates at Lock 2 is reported damaged and has been removed by C&RT. The Arm is shut till Monday when CRT will staff the lock three times a day until tghe beam can be replaced- possibly by Wednesday 23rd.
N
Hi
Came through Marsworth yesterday heading south and one of the balance beams had an undated notice stating the Aylesbury arm was closed UFN. There was a CaRT work boat above the top lock of the arm completely blocking passage also. HTH.
Cheers
David
This was E Mailed yesterday:
Notice Alert
Aylesbury Arm (Grand Union Canal)
Starts At: Lock 1
Ends At: Lock 2
Up Stream Winding Hole: Marsworth Junction
Down Stream Winding Hole: Below Lock 13
Saturday 19 July 2014 14:00 until Thursday 24 July 2014 14:30
Type: Advice
Reason: Structure failure
Update on 24/07/2014:
The balance beam at Lock 2 has been replaced. The canal is now fully open for cruising and boats can pass through this lock at any time.
