loubyscooby Posted June 30, 2012 Report Share Posted June 30, 2012 Can anyone offer some suggestions please; Despite changing the immersion heater I still don't have hot water. The old element was only 6 mths old but it would heat the water up but then you had to reset it so it has been changed however I still have the same problem. The new element was fitted on Monday so a tank of hot water but nothing since - what else could be the problem ? Link to comment Share on other sites More sharing options...
Ray Posted June 30, 2012 Report Share Posted June 30, 2012 You don't say what you have to reset? Is there a chance that the circuit breaker isn't rated high enough for the thermostat? Link to comment Share on other sites More sharing options...
loubyscooby Posted June 30, 2012 Author Report Share Posted June 30, 2012 Sorry Ray.... There is a cut off apparently and when the original heater needed "rebooting" for a better word you had to isolate the heater from the mains supply (just turned off all power to the boat) then remove the terminal cover and there is a small black button that you pushed to manually reset the master thermostat. This then worked until it stopped again. Im not sure about the circuit breaker, tbh I know little about the electrics but I can ask that question and see if thats the issue. Link to comment Share on other sites More sharing options...
Keeping Up Posted June 30, 2012 Report Share Posted June 30, 2012 That sounds like the overheat cut-out on the thermostat - in other words, the heating element is getting too hot. That probably means that it isn't surrounded by water as it should be, but by air instead. Could there be an airlock n the hot tank? It might help if you could describe it (is it vertical or horizontal, and where is the hot water taken out from?) Link to comment Share on other sites More sharing options...
Gibbo Posted June 30, 2012 Report Share Posted June 30, 2012 For the replacement, did you just buy a new element and refit the existing thermostat and cutout, or did you buy the complete fitting with a new thermostat and a new cutout already prewired? Link to comment Share on other sites More sharing options...
loubyscooby Posted June 30, 2012 Author Report Share Posted June 30, 2012 Hi Allan The tank is vertical but I'm not sure where the hot water comes out from - The top I think. Gibbo The whole thing was replaced with the thermostat and cut off already wired How would I know if I have air in the tank and if there is, how do I bleed it ? BTW, thanks for your help Link to comment Share on other sites More sharing options...
Gibbo Posted June 30, 2012 Report Share Posted June 30, 2012 There is something very odd here. The trip shouldn't pop until at least 15 degrees above the highest thermostat setting. But the thermostat measures the actual water temp, and as two different units have done the same thing, Allan's suggestion makes sense. But you say you got one tank full of hot water with the new one, then it tripped. So how can it be an air lock? You've got me beat! Link to comment Share on other sites More sharing options...
Tony Brooks Posted June 30, 2012 Report Share Posted June 30, 2012 There is something very odd here. The trip shouldn't pop until at least 15 degrees above the highest thermostat setting. But the thermostat measures the actual water temp, and as two different units have done the same thing, Allan's suggestion makes sense. But you say you got one tank full of hot water with the new one, then it tripped. So how can it be an air lock? You've got me beat! Could it be the engine heating the water to (say) 90C and popping the overheat whenever the OP runs his engine? Link to comment Share on other sites More sharing options...
Gibbo Posted June 30, 2012 Report Share Posted June 30, 2012 Could it be the engine heating the water to (say) 90C and popping the overheat whenever the OP runs his engine? Ahh now that's a possibility. You'd know better but I'm pretty sure modern engines get the cooling water even hotter than that. Link to comment Share on other sites More sharing options...
loubyscooby Posted June 30, 2012 Author Report Share Posted June 30, 2012 Sorry lads but the engine hasn't been run. In a marina, hooked up and not even had the CH on....... The mystery continues Link to comment Share on other sites More sharing options...
Gibbo Posted June 30, 2012 Report Share Posted June 30, 2012 Sorry lads but the engine hasn't been run. In a marina, hooked up and not even had the CH on....... The mystery continues Then I refer to my previous answer... You got me beat 1 Link to comment Share on other sites More sharing options...
loubyscooby Posted June 30, 2012 Author Report Share Posted June 30, 2012 When I find the answer I will let you know, in the meantime thanks anyway. Link to comment Share on other sites More sharing options...
Chalky Posted June 30, 2012 Report Share Posted June 30, 2012 (edited) There is the assumption that the mains is connected so that the thermostat is connected in circuit and is set to say 65 deg so that it controls the heating element. If the thermostat is not in circuit and the element is connected directly across the mains then this would function as described. If so then its wired incorrectly. Edited June 30, 2012 by Chalky Link to comment Share on other sites More sharing options...
Gibbo Posted June 30, 2012 Report Share Posted June 30, 2012 There is the assumption that the mains is connected so that the thermostat is connected in circuit and is set to say 65 deg so that it controls the heating element. If the thermostat is not in circuit and the element is connected directly across the mains then this would function as described. If so then its wired incorrectly. See post #5. That was the reason for the question. Link to comment Share on other sites More sharing options...
Keeping Up Posted June 30, 2012 Report Share Posted June 30, 2012 I don't understand water properly because I can't usually measure it with a voltmeter but taking a guess on the "trapped air" theory, could the pump possibly be sucking in some air which is then getting stuck at the top of the tank - possibly even if there is no hot water being drawn off? If the outlet is from the very top of the tank, opening a hot tap should get rid of it after some spluttering at the tap, but if the outlet is merely "near" the top there is a possible space for air to hide in. If so, is there a Pressure Release Valve that could be used to bleed it? Alternatively is the pump ever being switched right off, which could draw air back in through the hot taps or the PRV? Link to comment Share on other sites More sharing options...
Gibbo Posted June 30, 2012 Report Share Posted June 30, 2012 I don't understand water properly because I can't usually measure it with a voltmeter You can if you connect it up properly Link to comment Share on other sites More sharing options...
loubyscooby Posted July 1, 2012 Author Report Share Posted July 1, 2012 Thank you to everyone for your help. I am having someone look at it this week so will keep you posted. Link to comment Share on other sites More sharing options...
loubyscooby Posted August 3, 2012 Author Report Share Posted August 3, 2012 Well I forgot to update this and report the solution to the problem. Two guys came from the boat yard and after working on it and emptying and filling the tank 3 times they realised the problem and set about fixing it. It was a very complicated procedure................. they turned the thermostat down 5 degrees as it was overheating !!! Allan, Gibbo and Ray you were all right so thank you I bet they wish they had thought of that before replacing the heating element twice. Happy to report no problems since. Link to comment Share on other sites More sharing options...
Tom and Bex Posted August 3, 2012 Report Share Posted August 3, 2012 Only just seen this post but that is exactly what happened to ours. Kept cutting out after 1 tank and needing to be reset. Turned cut out thermostat up slightly after removing sticker and been fine ever since. Mine was new and pre wired and pre set as well but both thermostats were set to about the same temp. Glad you got it sorted. Tom Link to comment Share on other sites More sharing options...
