Biggles Posted February 9, 2011 Report Share Posted February 9, 2011 Can someone please tell me what to order from the screwfix catalog to connect 22mm copper to the coils on a copper cylinder. Cheers Biggles Link to comment Share on other sites More sharing options...
Ark Right Posted February 9, 2011 Report Share Posted February 9, 2011 Can someone please tell me what to order from the screwfix catalog to connect 22mm copper to the coils on a copper cylinder. Cheers Biggles I hope this is non boat related If it then In would be more than happy to point you in the right direction Link to comment Share on other sites More sharing options...
springy Posted February 9, 2011 Report Share Posted February 9, 2011 Depends on the size of the fittings on the coil - they are probably either 1" BSP male - in which case you could use http://www.screwfix.com/prods/50777/Plumbing/Compression-Fittings/Flowflex-Female-Coupler-22mm-x-1 or http://www.screwfix.com/prods/96133/Plumbing/Compression-Fittings/Flowflex-Female-Coupler-28mm-x-1 with a 28-22 reducing bush Or they may be 3/4" BSP male in which case you could use http://www.screwfix.com/prods/81402/Plumbing/Compression-Fittings/Flowflex-Female-Coupler-22mm-x elbows are also available and screwfix list several brands - prices vary & I can't comment on quality springy Link to comment Share on other sites More sharing options...
david and julie Posted February 9, 2011 Report Share Posted February 9, 2011 Personally I'd go for the union type. http://www.plumbcall...nder-Unions.htm Link to comment Share on other sites More sharing options...
Strads Posted February 10, 2011 Report Share Posted February 10, 2011 mine were 22mm and i used compresion joints on one pair and have hep ones on the other (as installed) and they fecking awkward to undo / and will if i have to "remove" work on the calorifier again be changed for compresion joints..as i can get "leverage" on these to tighten - undo when needed...... Link to comment Share on other sites More sharing options...
