Biggles Posted September 16, 2010 Author Report Share Posted September 16, 2010 So I can see how this would work with a flow switch on the shower feed but what about actuating on a waste flow. i.e. When the plug is pulled out of a bath. Biggles Link to comment Share on other sites More sharing options...
c c Posted September 16, 2010 Report Share Posted September 16, 2010 So I can see how this would work with a flow switch on the shower feed but what about actuating on a waste flow. i.e. When the plug is pulled out of a bath. Biggles Assuming you get out of the bath at some point, whats wrong with a switch on the wall to empty it. It is only 12 volts but you could even have a pull switch from the ceiling. Link to comment Share on other sites More sharing options...
Evo Posted September 16, 2010 Report Share Posted September 16, 2010 Our shower bath has a Jabsco. Its done 10 years so far with no maintenance at all, and still works aswell as it did when new. Its very quick at emptying the bath, a fantastic little pump, can run dry and can be situated above water level. I have it on a manual switch. For a shower I switch it on as I go in and off when I get out. Bloody hell, its such an effort, I dont think I'll be able to cope much longer, I wish it came on automatically, I'd have more electrical stuff to play with when it goes wrong then. 1 Link to comment Share on other sites More sharing options...
nb Innisfree Posted September 16, 2010 Report Share Posted September 16, 2010 A pull switch inside the shower enclosure is best IMO, you can leave it off if you want to soak your feet a bit and it is conveniently at hand to operate (we have a cork key fob on the end of the cord - easy to grasp) also you can leave it on for a while after the shower is turned off, there is no danger of inadvertently leaving it on due to the noise it makes. Link to comment Share on other sites More sharing options...
Neil TNC Posted September 16, 2010 Report Share Posted September 16, 2010 So I can see how this would work with a flow switch on the shower feed but what about actuating on a waste flow. i.e. When the plug is pulled out of a bath. Biggles The flow switch mentioned is incorporated in a bit of 15mm copper pipe. It has to be set vertically, with flow from bottom to top. It consists of a magnetised pelett, within restrictions in the tube, that is drawn upwards by the flow, this actuates a reed switch on the side. So me no thinky this will work in a drain, without the expense of buying another type of flow switch, which tend to be rather more expensive. I am not advocating the use of this kit, but I got it "free" with my 30 quid gulper, so may have a play with it. I will have a bypass switch, much like I do with the "float" switch, on the totally cr@p Attwood shower sump box I was lumbered with on Earnest. (it is so shoe-horned in, that I have never dared to replace it with a gulper) Link to comment Share on other sites More sharing options...
Colin Smith Posted September 16, 2010 Report Share Posted September 16, 2010 I've got one of the new Gulper IC pumps and the IC gulley. Fully automatic start and stops when the gulley is empty for 15 seconds, then runs for a few more seconds to empty the drips! Absolutely fantastic if a bit expensive but I expect that it will pay for itself over the years and no messing about with in-line flow switches or having to turn it on/off etc. http://www.whale-pumps.com/documents/brochure/IC_New_Brochure0810.pdf Colin Link to comment Share on other sites More sharing options...
