Tusses Posted March 24, 2008 Report Share Posted March 24, 2008 I like to ponder all things, and question everything that others take for granted ! so ... I was thinking 240v lighting using cheap and reliable low energy bulbs. The thought was to have a separate small inverter just for a 240v lighting circuit. Halogens are quite 'thirsty' and LED's aren't quite there yet - price and reliability wise. Anyone know what the efficiency of various inverters are ? standby/quiescent current ? would only need to be a small one - say 150w or so. do any of them 'current sense' , shutting down with no load ? Link to comment Share on other sites More sharing options...
steelaway Posted March 24, 2008 Report Share Posted March 24, 2008 I like to ponder all things, and question everything that others take for granted ! so ... I was thinking 240v lighting using cheap and reliable low energy bulbs. The thought was to have a separate small inverter just for a 240v lighting circuit. Halogens are quite 'thirsty' and LED's aren't quite there yet - price and reliability wise. Anyone know what the efficiency of various inverters are ? standby/quiescent current ? would only need to be a small one - say 150w or so. do any of them 'current sense' , shutting down with no load ? Hi There Have you thought about using cheap and reliable low energy 12V bulbs. They are called flourescents in 6w/12w/18w There are lots about Alex Link to comment Share on other sites More sharing options...
Tusses Posted March 24, 2008 Author Report Share Posted March 24, 2008 Hi There Have you thought about using cheap and reliable low energy 12V bulbs. They are called flourescents in 6w/12w/18w There are lots about Alex I had heard they can be quite 'harsh' . You can get 240v ones that give a pleasant light. Are there decent 12v florescents nowadays then ? are the bulbs as cheap as 240v ones - like 99p each or less ! ? like I said - I might dismiss the idea - I just like to ponder these things Link to comment Share on other sites More sharing options...
chris w Posted March 24, 2008 Report Share Posted March 24, 2008 Halogens are quite 'thirsty' ............... Halogens are actually more efficient than normal tungsten filament lamps. Chris Link to comment Share on other sites More sharing options...
sueb Posted March 24, 2008 Report Share Posted March 24, 2008 I had heard they can be quite 'harsh' . You can get 240v ones that give a pleasant light. Are there decent 12v florescents nowadays then ? are the bulbs as cheap as 240v ones - like 99p each or less ! ? like I said - I might dismiss the idea - I just like to ponder these things Dismiss the idea. Batteries cost a lot more than light bulbs Sue Link to comment Share on other sites More sharing options...
Chris Pink Posted March 25, 2008 Report Share Posted March 25, 2008 I was thinking 240v lighting using cheap and reliable low energy bulbs. You can get the same low energy (folded up flourescent) bulbs in 12V versions but, unfortunately, not as cheaply as the 240V ones. Link to comment Share on other sites More sharing options...
