Hairyloon Posted February 21, 2008 Report Share Posted February 21, 2008 I've been considering getting a boat. One of the ones I was looking at is an unfinished ferrocement project and in a couple of places I can see the beginnings of rust in the steel rods. My thinking is that if the water can get to the steel, then the rust will expand and crack off the plaster. Or it may be just a bit that rusted during construction and is now stable. My experience of ferrocement is almost zero, so any advice anyone? Link to comment Share on other sites More sharing options...
carlt Posted February 21, 2008 Report Share Posted February 21, 2008 I've been considering getting a boat. One of the ones I was looking at is an unfinished ferrocement project and in a couple of places I can see the beginnings of rust in the steel rods.My thinking is that if the water can get to the steel, then the rust will expand and crack off the plaster. Or it may be just a bit that rusted during construction and is now stable. My experience of ferrocement is almost zero, so any advice anyone? Steer clear, would be my advice. Your thinking is spot on and there isn't really any way back, once the concrete starts to separate from the reinforcement. I do know someone who forced more cement, into the cracks, but I think he just delayed the inevitabe. Of course, if you can see the rods, then they're exposed to the atmosphere and that bit would corrode anyway, but can you tell whats going on underneath? Link to comment Share on other sites More sharing options...
ChrisPy Posted February 21, 2008 Report Share Posted February 21, 2008 Light rust on reinforcing steel is not a problem, in fact it increase the bond between the steel and the concrete. The lime in concrete naturally protects the steel against further corrosion under normal circumstances - that is why it is common practice to apply limewash to the inside of water tanks. If you see a reinforcing steel cage in a building before concreting which is not rusty, it is probably because the steel is covered in dark-grey millscale. Unless the cage has been specially treated this will fall off in a short time, and the steel will rust. Light rust is not considered to be a problem. Rust is not a disease of the steel: if the conditions are not right, then further rusting will not occur. By the same token, non-rusty steel embedded in cement/concrete will soon rust if the conditions allow (eg cracks and sea water). So it is vitally important that there are no surface cracks that would allow water (especially sea water) to migrate to the steel, where the salt content will negate the lime protection and cause accelerated corrosion. Ferrocement boats should be well sealed with appropriate paint coatings to avoid this. In aggressive environments it is common practice to apply cathodic protection to the reinforcing steel - the same should be possible for boats. If you inherit a steel armature ready for 'plastering' you can always gritblast it or wirebrush it to remove heavy rust, but of course the light rust will immediately appear again before you can enclose the steel in plaster. If you need further in-depth advice there are some very good books on the subject. Hartley's of New Zealand is a good source of information and advice. Link to comment Share on other sites More sharing options...
badgerburger Posted February 21, 2008 Report Share Posted February 21, 2008 Hi, HairyLoon. How about posting some pictures - especially close-up of the rust? Also, does anyone know how to tell whether ferrocement has surface cracks, or should these be obvious ?? BB Link to comment Share on other sites More sharing options...
ChrisPy Posted February 21, 2008 Report Share Posted February 21, 2008 Also, does anyone know how to tell whether ferrocement has surface cracks, or should these be obvious ?? I would assume it has (even just micro-cracks) and treat the surface with a very good coating. Google for 'ferrocement surface painting' will give lots of information. Link to comment Share on other sites More sharing options...
Malarky Posted February 21, 2008 Report Share Posted February 21, 2008 I think you'll find Ferro-cement unpopular, as the science involved is just not beautifull compared to, say wood, but steel, although not as scary is pretty horrid too, despite all it's beauty. This could make this boat extremely cheep if you tune in to all the bad points with cement boating! To add to Chris's comments, the rust can also act to "grease" any movement due to the diffrence in expansion rates of steel and the cement, which, incidently has the same rate as glass.. I,m intrigued, is it a narrowboat? Would be great to see some pic's. Ever thought of building one? Link to comment Share on other sites More sharing options...
ChrisPy Posted February 22, 2008 Report Share Posted February 22, 2008 The best ferro boats are 'shapely' - they derive much strength form the spherical 'eggshell' shaped surfaces - which is why it is often used for blue water cruising yachts and fishing boats, where the cost of fabricating a decent shaped steel or timber hull is significant. It is not suited to narrowboat construction, which is all flat surfaces, and where welding steel plates together gives a relatively cheap product that can stand the knocks (because it is resilient) without needing excessive framing. A dent in a steel hull can be tolerated, a dent in a ferro hull has broken the structure and needs extensive repair. Link to comment Share on other sites More sharing options...
Malarky Posted February 22, 2008 Report Share Posted February 22, 2008 The best ferro boats are 'shapely' - they derive much strength form the spherical 'eggshell' shaped surfaces - which is why it is often used for blue water cruising yachts and fishing boats, where the cost of fabricating a decent shaped steel or timber hull is significant. It is not suited to narrowboat construction, which is all flat surfaces, and where welding steel plates together gives a relatively cheap product that can stand the knocks (because it is resilient) without needing excessive framing. A dent in a steel hull can be tolerated, a dent in a ferro hull has broken the structure and needs extensive repair. This may help explain why I've never seen one, and after hearing about a fero-cement narrow boat, several years ago, it has been niggleing me as how to sensibly build such a thing! I suppose I was "had" there then! Link to comment Share on other sites More sharing options...
Hairyloon Posted February 23, 2008 Author Report Share Posted February 23, 2008 (edited) Thanks for the input. Since you ask: I don't have a close up of the areas of concern, I may go back for another look. I couldn't see any visible cracks, but I didn't look very closely, I'd already got scared by the size of the project and was about to run away. Have recently been rethinking. And yes, I have thought about building one, I don't know how, but I do have potential use of a boathouse, but the only practical way to get to the boathouse is by boat... Edited February 23, 2008 by Hairyloon Link to comment Share on other sites More sharing options...
ChrisPy Posted February 24, 2008 Report Share Posted February 24, 2008 nice shapely hull, but out of place on inland waterways, I think. Link to comment Share on other sites More sharing options...
carlt Posted February 24, 2008 Report Share Posted February 24, 2008 This may help explain why I've never seen one, and after hearing about a fero-cement narrow boat, several years ago, it has been niggleing me as how to sensibly build such a thing! I suppose I was "had" there then! Concoform, at weedon, built them, in the 70s and a chap near Nottingham (who's name escapes me). There are still a few about, there's one in quite good nick at Sutton stop, and one, in not such good nick (I think the wooden top deteriorated and collapsed) which gets dragged around the Oxford by someone who can't bring himself to leave it. Link to comment Share on other sites More sharing options...
Hairyloon Posted February 24, 2008 Author Report Share Posted February 24, 2008 nice shapely hull, but out of place on inland waterways, I think. 'salright, it's on the yard. Link to comment Share on other sites More sharing options...
denboy Posted February 24, 2008 Report Share Posted February 24, 2008 there used to be one in excelent condition moored at cranfleet dont know if its still there Link to comment Share on other sites More sharing options...
mikeys Posted October 1, 2008 Report Share Posted October 1, 2008 Concoform, at weedon, built them, in the 70s and a chap near Nottingham (who's name escapes me). There are still a few about, there's one in quite good nick at Sutton stop, and one, in not such good nick (I think the wooden top deteriorated and collapsed) which gets dragged around the Oxford by someone who can't bring himself to leave it. carlt must have been sometime ago you saw my ferro boat at sutton stop its been at rugby for last eight years looking very good fitted out now reading other comments on ferro mine is forty five foot long and is powerd by lister sr2 engine Link to comment Share on other sites More sharing options...
carlt Posted October 1, 2008 Report Share Posted October 1, 2008 I'm in Rugby. I'll wander up and have a nosey, sometime. Link to comment Share on other sites More sharing options...
Guest TerryL Posted October 1, 2008 Report Share Posted October 1, 2008 I've been considering getting a boat. One of the ones I was looking at is an unfinished ferrocement project and in a couple of places I can see the beginnings of rust in the steel rods.My thinking is that if the water can get to the steel, then the rust will expand and crack off the plaster. Or it may be just a bit that rusted during construction and is now stable. My experience of ferrocement is almost zero, so any advice anyone? I've got a professionally built to Loyds spec ferro motorsailer, I'm very pleased with it. Are the exposed rods inside? If so they just need painting but there shouldn't be any showing outside. Link to comment Share on other sites More sharing options...
mikeys Posted October 2, 2008 Report Share Posted October 2, 2008 I'm in Rugby. I'll wander up and have a nosey, sometime. No problem here most of time doing somthing, the boatbuilder you were on about from nottingham was Davidsons they built six in late 60s of which mine is one of them the hulls all came from Poole and they did fit out they all then went onto the broads as hire boats this according to a guy that worked for them and saw mine while still at sutton any look forward to seeing you Link to comment Share on other sites More sharing options...
pirate paul Posted July 24, 2009 Report Share Posted July 24, 2009 I've been considering getting a boat. One of the ones I was looking at is an unfinished ferrocement project and in a couple of places I can see the beginnings of rust in the steel rods.My thinking is that if the water can get to the steel, then the rust will expand and crack off the plaster. Or it may be just a bit that rusted during construction and is now stable. My experience of ferrocement is almost zero, so any advice anyone? Hi I am looking for a very cheap ferro boat, if your not interested in this vessil I am... any chance of a contact email or number. Tar & stuff Link to comment Share on other sites More sharing options...
ThePiglet Posted July 24, 2009 Report Share Posted July 24, 2009 (edited) It's probably sunk by now Edited July 24, 2009 by ThePiglet Link to comment Share on other sites More sharing options...
nb Innisfree Posted July 24, 2009 Report Share Posted July 24, 2009 No problem here most of time doing somthing, the boatbuilder you were on about from nottingham was Davidsons they built six in late 60sof which mine is one of them the hulls all came from Poole and they did fit out they all then went onto the broads as hire boats this according to a guy that worked for them and saw mine while still at sutton any look forward to seeing you I think the world's first concrete boat was built at Poole about 1905, quite a big one. Built near to or on the site of Sunseeker if I recall correctly. Link to comment Share on other sites More sharing options...
pirate paul Posted July 25, 2009 Report Share Posted July 25, 2009 The best ferro boats are 'shapely' - they derive much strength form the spherical 'eggshell' shaped surfaces - which is why it is often used for blue water cruising yachts and fishing boats, where the cost of fabricating a decent shaped steel or timber hull is significant. It is not suited to narrowboat construction, which is all flat surfaces, and where welding steel plates together gives a relatively cheap product that can stand the knocks (because it is resilient) without needing excessive framing. A dent in a steel hull can be tolerated, a dent in a ferro hull has broken the structure and needs extensive repair. There was a ferro barge at Portsmouth, opposit the old submarine and ship scrapyard......That was about 4 or 5 years ago. 100ft or so! Link to comment Share on other sites More sharing options...
carlt Posted July 26, 2009 Report Share Posted July 26, 2009 (edited) I think the world's first concrete boat was built at Poole about 1905, quite a big one. Built near to or on the site of Sunseeker if I recall correctly. Sorry, but I'm sure it was a French invention, mid 19th century, iirc. Edited to say: Yep, Google tells me it was Joseph-Luis Lambot, in 1847. Edited July 26, 2009 by carlt Link to comment Share on other sites More sharing options...
Greybeard Posted July 26, 2009 Report Share Posted July 26, 2009 I'd never really heard of ferro boats before so this is an interesting subject - I think I've actually spotted one under a tarpaulin in a farmers field. I'm going to check it out to find out for sure. As an aside http://www.concretesubmarine.com/ looks interesting. Wouldn't get far up the T&M though! Mike Link to comment Share on other sites More sharing options...
