wandering snail Posted July 26, 2022 Report Share Posted July 26, 2022 Long shot but has anyone a Switzer SZ-3200i generator? If so, do you know which spark plug it uses? We've been given one without one and can't find a manual online. Link to comment Share on other sites More sharing options...
Tony Brooks Posted July 26, 2022 Report Share Posted July 26, 2022 Measure the depth of the thread and diameter. That should get you a plug that fits. If you can choose one WITHOUT and extended nose so there is no chance of it hitting the piston. Once that is done you only have to worry about the heat range (running temperature of the ceramic tip). A good supplier should know about the heat range so choose a middle one. If it oils up go hotter, if the tip goes very white go colder. Without a manual that is the best I can do, hope someone else actually knows. Link to comment Share on other sites More sharing options...
Tracy D'arth Posted July 26, 2022 Report Share Posted July 26, 2022 (edited) Measure the depth from the top of the thread to the bottom to give the plug reach and make sure that there is room below this to the piston crown at top dead center for the electrode whether extended nose or not. Find a motorbike or lawn mower engine, about the same capacity, and try that spark plug. 2 stroke or 4 stroke? It makes a difference. Generator Guru lists this for the 3600i genny https://www.generatorguru.com/spark-plug-75165997/ Edited July 26, 2022 by Tracy D'arth Link to comment Share on other sites More sharing options...
wandering snail Posted July 26, 2022 Author Report Share Posted July 26, 2022 6 minutes ago, Tracy D'arth said: Measure the depth from the top of the thread to the bottom to give the plug reach and make sure that there is room below this to the piston crown at top dead center for the electrode whether extended nose or not. Find a motorbike or lawn mower engine, about the same capacity, and try that spark plug. 2 stroke or 4 stroke? It makes a difference. 4 stroke Link to comment Share on other sites More sharing options...
Tracy D'arth Posted July 26, 2022 Report Share Posted July 26, 2022 Generator Guru lists this for the 3600i genny https://www.generatorguru.com/spark-plug-75165997/ You can ask them on line, they are usually very helpful. If the picture on the site is a true representation ( not guaranteed ) of the spark plug, then its an extended nose long reach like an N9Y or an N11Y but do make sure that the piston will not hit it Link to comment Share on other sites More sharing options...
wandering snail Posted July 26, 2022 Author Report Share Posted July 26, 2022 Many thanks for the input. Sadly it's R.I.P, the inverter control board has been burnt out. Link to comment Share on other sites More sharing options...
MtB Posted July 26, 2022 Report Share Posted July 26, 2022 22 minutes ago, wandering snail said: Many thanks for the input. Sadly it's R.I.P, the inverter control board has been burnt out. Don't lose hope. There are people about who love fixing control boards. Someone like Geoff at cetltd.com might cruise it if you send it to him. Or he might dismiss it out of hand depending on his mood when you catch him. Link to comment Share on other sites More sharing options...
