Idle Days Posted April 16, 2022 Report Share Posted April 16, 2022 Any ideas regarding Sikaflex removal from a painted roof, apart from using their very expensive 208 remover? Link to comment Share on other sites More sharing options...
Tonka Posted April 16, 2022 Report Share Posted April 16, 2022 10 minutes ago, Idle Days said: Any ideas regarding Sikaflex removal from a painted roof, apart from using their very expensive 208 remover? I have only ever used the remover. If you are planning on a repaint you will only regret it if you use something else and end up with a dodgy finish 1 Link to comment Share on other sites More sharing options...
Tracy D'arth Posted April 16, 2022 Report Share Posted April 16, 2022 2 hours ago, Idle Days said: Any ideas regarding Sikaflex removal from a painted roof, apart from using their very expensive 208 remover? Find out what the 208 remover is. It will be a thinners of some sort, white spirit, cellulase thinners, acetone etc. The label on the can will tell you. Or find the Coshh regulations. 1 Link to comment Share on other sites More sharing options...
Chris Lowe Posted April 16, 2022 Report Share Posted April 16, 2022 12 minutes ago, Tracy D'arth said: Find out what the 208 remover is. It will be a thinners of some sort, white spirit, cellulase thinners, acetone etc. The label on the can will tell you. Or find the Coshh regulations. Sikaflex 208 MSDS attached.Sika Remover 208 - MSDS.pdf Link to comment Share on other sites More sharing options...
Tracy D'arth Posted April 16, 2022 Report Share Posted April 16, 2022 (edited) 21 minutes ago, buccaneer66 said: Sikaflex 208 MSDS attached.Sika Remover 208 - MSDS.pdf A complex Hydrocarbon compound. The formula is in here https://echa.europa.eu/substance-information/-/substanceinfo/100.130.209 Looks to be mainly Xylene with Benzine. Edited April 16, 2022 by Tracy D'arth 1 Link to comment Share on other sites More sharing options...
Chris Lowe Posted April 16, 2022 Report Share Posted April 16, 2022 I have loads of these saved as I have to supply O & M information for building handovers. Link to comment Share on other sites More sharing options...
