carsten Posted May 30, 2021 Report Share Posted May 30, 2021 Hi from Italy. I am using a sabb 2j in my aluminium sailboat and its running like a watch.......4000 hrs. So far i only change oil and take good diesel and had only two problems in the past. The waterpump valves broken and the governor get stuck by a simple spring..... Thinking about checking valves and injector but normally i never touch a running system......no smoke and running 200 hrs a year. Time to time i need the water pump diaphragm and now no spares are left. I only know Sleeman but they charge 40 pound for one 70mm rubber diaphragm !!! Are there any reasonible part supplier available ? He is getting a little oily but i call it corrosion protection and i am sweating myself when i am running.... Thanks a lot in advance Carsten Link to comment Share on other sites More sharing options...
buccaneer66 Posted May 30, 2021 Report Share Posted May 30, 2021 Welcome to the forum Carsten someone with better knowledge than me will be along soon. Link to comment Share on other sites More sharing options...
Ray T Posted May 30, 2021 Report Share Posted May 30, 2021 (edited) Try Union Canal Carriers, they run a fleet of Sabb engined hire boats. Union Canal Carriers | Contact Us Edited May 30, 2021 by Ray T 1 Link to comment Share on other sites More sharing options...
carsten Posted May 31, 2021 Author Report Share Posted May 31, 2021 thks , send email rightaway. Link to comment Share on other sites More sharing options...
PaulJ Posted May 31, 2021 Report Share Posted May 31, 2021 Spares are a bit dear Im afraid. I fitted a new thermostat and it makes that diaphragm look cheap. Wont mention the cost of the head gaskets ? The injectors are fairly standard and I had my pumps and injectors sorted by a local diesel specialist at a very reasonable cost. Never found anyone else other than Sleeman & Hawkins either. On the bright side I have never needed many spares other than to sort out the many bodges carried out by the previous owner. Link to comment Share on other sites More sharing options...
carsten Posted May 31, 2021 Author Report Share Posted May 31, 2021 yes i know, we are not paying the parts but the availability of 30 years......luckily the first owner left some parts on the boat like set of gaskets, fuel pipes and 8 of the diaphragm but over the years in seawater they get brittle. A fuelpump i found via ebay at the manufacturer in italy some years ago, an started are availabf from third parties if necessary but genuie Sabb parts are like gold. In norway they cost the same.... But i aam sure that the rubber will be used in some other engine too and Sabb is not the manufacturer. In my parts i found a third party diaphragm made by KACO, but they are not producing it anymore. But i like the engine, a little weak for my 16 ton boat when it gets windy but for the moment i will keep the sabb. At 40 knots wind i make 2 knots in the wind..... Link to comment Share on other sites More sharing options...
Canal321 Posted May 31, 2021 Report Share Posted May 31, 2021 On 30/05/2021 at 18:51, carsten said: Time to time i need the water pump diaphragm and now no spares are left. I only know Sleeman but they charge 40 pound for one 70mm rubber diaphragm !!! Are there any reasonible part supplier available ? I bought a sabb 2j from Marine Enterprises, Dorset a couple of years ago. Sean there had 2 complete engines and 4 more stripped for parts. As part of the sale of the engine to me, he replaced the water pump diaphragm. So I think he would be worth a try. http://www.marineenterprisesltd.co.uk/ Link to comment Share on other sites More sharing options...
