Roxylass Posted June 17, 2020 Report Posted June 17, 2020 Coming back to the mooring today put the revs right down almost idle sr2stopped started first turn when I was going out ignition light went out touch of revs probally a two hour run didn’t go above half throttle carry an aux but still like to know why engine cut out at idle
Tony Brooks Posted June 17, 2020 Report Posted June 17, 2020 Is the oil level going up and does the oil feel thin & smell of diesel? All those air cooled Listers have a nasty habit of leaking fuel into their oil and that can cause partial seizure that causes the engine to stop when it drops to tickover.
Roxylass Posted June 17, 2020 Author Report Posted June 17, 2020 Hi Tony Oil pressure never moved at all No smell out of the ordinary Oil still shows clean on the dipstick Couple of minutes to tie the mooring lines on turned the key started no problem
Tony Brooks Posted June 17, 2020 Report Posted June 17, 2020 If it keeps doing it see what happens if you try it with the fuel filler cap off.
PaulJ Posted June 17, 2020 Report Posted June 17, 2020 Are your air ducts present/connected and clear. My old one used to do that when it got a bit warm..
Roxylass Posted June 17, 2020 Author Report Posted June 17, 2020 Thanks tony if it happens again I shall try this Paul J no restriction to the air at all
PaulJ Posted June 17, 2020 Report Posted June 17, 2020 15 minutes ago, Roxylass said: Thanks tony if it happens again I shall try this Paul J no restriction to the air at all Aah well-thought Id try the cheapest possibility first . The next time I came across this problem the engine actually had no oil in it. That was several years ago and as far as I know the owner is still happily chugging about with it ? Robust engines them..
