My MX60 has been running great for last couple of years, I clean and service it once a year.
Recently it has started to run a bit below par. After the start up phase the fan/motor runs a lot slower and never runs as fast as it used to do
In the past it would run great and heat the hot water tank and radiators just fine.
Now it still runs but seems to be running slower than in the past and the radiators and take longer to heat up and never get to full temperature.
Have removed the burner end cover and cleaned everything and also cleaned the flame detector.
Are there any typical issues that are likely to cause this problem or any ideas what I should be looking at more closely to get it back running 100% ?
After some problems with my mx60 and doing the usual stuff like fuses and glow plug etc etc my fault was diagnosed as the brain box had gone tits up. A new box of tricks solved the problem.
5 minutes ago, rustynewbery said:
How much did that set you back?  The Eber brain is around £300
I don't recall it was 3 boats ago on the Udson. Iirc it was more than that.
Now sorted....dodgy connection on a thermocouple, the one telling control unit water is hot.
Found it loose so re-crimped the terminal and its all working perfectly again.
Great news :)
Thanks for coming back and letting us know.
How had the connection become loose? Corrosion, vibration?
11 hours ago, WotEver said:
Great news :)
Its in my engine bay and I must have caught it on clothing while getting out of there. In doing so the connector got snagged and opened up a bit so making it loose. So it looked like it was in place but it wasnt connecting.
