Hi folks.
My Lister Lpws4 has a leaky low oil pressure sender. I think it must have been weeping for a while but I now think it is getting worse. The audible alarm stops when I start the engine, but I'm not sure if this alarm is also connected to the charge circuit. I don't appear to have a lighting up pressure  warning light on the warning light panel.
Before I change the sensor, I would like to find out what the 3 terminals are for. I am familiar with the  single wire type connected on car's.  3 terminals seems two too many! Are they, + (feed), buzzer and light? As the unit is leaky, I guess it may be the cause of the  warning lamp failure.
On a car it would be a simple case of touching the  sender +feed to earth, I fear if one of these wires is live, touching it to earth might blow something, as might connecting a live feed to one of the other terminals?
I have no idea where I could get hold of a wiring diagram.
Thanks in anticipation,
Patrick.
4 minutes ago, Plonk said:
Hi folks.
Patrick.
Electric pressure gauge and oil light?
Send me a PM with your email address and I'll send you the workshop manual (110 pages - should show what you want)
I cannot attach it here as it is a Pdf (which are not allowed to be attached)
Edited by Alan de Enfield
That’d be my guess.
Plonk - do you have an oil pressure gauge?
No guage, just buzzer and light. There is a big white control box in the engine comparment though!
The sender looks like a normal small low pressure warning sender
 I guess just simple contact switch inside.
Unfortunately the manual online only goes to page 109. Wiring is on page 129.
On thinking about it,. I would guess that the wiring might  be 12v feed, buzzer out 12v no pressure,  light out 12 v pressure. ? I will hopefully figure it out when the new switch comes.
Edited by Plonk
It’s a changeover type switch (spdt) touch the non black wire to earth to check wiring / bulb
sounds like bulb has gone if buzzer working. It has no impact on charging unless none of the lights are working which is a different issue I would think
Big white box isn’t relevant although check the two circuit breakers on the top of the box one is for the stop solenoid and I think t’other supplies the instruments.
oops -sorry I'll email that section.
The 'most important one & I didn't send it.
I just tried emailing it and got an 'expired error'
Ok - got it to work this time
46 pages - Industrial engines first, then scroll down for Marine engines.
Alan
