Nope ....WW2......and its quite correct that pre 1940 CAV stuff is much better made than 1970 s CAV stuff............. Ive found the Indian made Bosch injection equiptment is just as good as CAV ,at least........far as I know,there is no mechanical injection made in eurozone any more.....Actually,the very best of the Bosch licence diesel pumps were made in Japan......Denso and Kiki.....
Again thank you the depression next to the LH pump which did not appear to be leaking was full of engine oil whereas the one next to the RH pump which appears to have the leak, was full of mainly diesel, I will work my way round all the unions tightening up and replace washers as necessary
Thanks everyone replacement washers and one replacement bleed screw seems to have improved matters a lot, starting to understand the engine a bit more now
Have you found the surprising fuel filter?
MP.
no not sure about fuel filter, there are two in line between day tank and the engine
There should be one under a cover on top of the engine. It is shaped like a big spiral, about six inches across
The chamber that it sits in can get cracked by water and frost, so it isn't unusual to find that filter has been bypassed
The filter is in the manual
Richard
This presumably, is the 'surprise' mentioned by MoominPapa in post 29......
No, the surprise is usually 'so that's where the filter is!'
Richard
Richard
Or, if you have a day tank "where is all this diesel coming from?" when you remove the innocuous looking cover across the front of the block.
MP.
MP.
:giggles:
Thanks all I have obviously lots more surprises to come wth this engine
I have an ongoing thing with a customers FR, it likes to hide it's oil from time to time
Mine once hid its oil by mixing it with a  lot of diesel and filling the the oil tank, crankcase and engine bilge with the mixture.
MP.
MP.
This one likes to empty the sump and the oil tank, but not fill the bilge
It hides the oil in the gearbox
Richard
Richard
I thought that was fixed by unblocking the drain pipe?
MP.
