plainsman
Member Map
Calendar
Community Map
Everything posted by plainsman
I understand Mersey and three other boats were lifted by CRT Sec 8 from the L&L near Burscough.
Depends how much further north. St Mary's Marina and Fettlers Wharf Marina on the Ruffled Branch Leeds Liverpool, literally a stone's throw from rail station with easy links to West coast mainline.
Leisure batteries - advice on what to buy
plainsman replied to cairanvanrooyen's topic in Build Blogs
Yep, go for the cheap ones. Don't run them to low, check electrolyte regularly and land line charge if poss. I bought mine from Tanya Batteries eight, yes eight years ago. They still serve my needs and I cruise about three or four hours a day then a couple of days stop over without further charging until I get back to base. Or if on a long cruise I may overnight in marina with hook up to top the batts up. If I got expensive batteries I'd be scared to death of wrecking them. -
Source for metal/hard plastic rings
plainsman replied to plainsman's topic in Boat Building & Maintenance
You've rumbled what I'm building. Seriously it's make my own or redesign. I'll think about it over the weekend. Thanks for the links -
Good idea, my next port of call -
It's an extension to a piece of moving artwork, the spec for the ring (metal or hard plastic) is 56mm internal diameter, round profile cross section 3 of 4 mm. Because of the design a 'just about' internal dia won't work with project in its current form. Seems I've learnt the hard way to hear sizes are not an industry standard so I will have to rethink. Thanks for everyone's help -
Thanks David and Nomad, link useful but unfortunately no sizes I need. Think I'll have to rethink my project. Cheers -
Hope someone can help me out, I am trying without much luck to source metal (preferably polished metal s/s etc) ring with internal diameter 56mm and cross section of say 3 or 4mm. I've done the eBay and Googled but drawn a blank. Help appreciated
Travelling on the Shroppie at Hurleston Junction I noticed. Series of white posts in groups of two, three and four. They on the embankment of the resovoiur dam opposite the main line towpath. Any idea what they are for? Have asked a couple of locals and long-term moorers but no luck. Satisfy my curiosity please.
Handy place to stop to clear prop of local junk
Cleaning clear plastic cratch windows
Thanks MartynG and Nightwstch -
Need a bit of help here, what's the best way to clean cratch flexible windows. Have seen loads of expensive car hood cleaners but is there a simple method?
It's the inconsistency I am complaining about , viz marinas are 'holiday accommodation' for March restrictions but not holiday accommodation for vat relief. BTW I use marinas often for overnight or longer when cruising.
Just to let you know I have written to my MP pointing out the injustice. That is marinas were classed as holiday accomodation when the restrictions were imposed but not so for reduced VAT. Another inconsistency in govt management of Covid crisis. Not sure what good it will do but if others did the same it might stand a chance
Thanks for the tips particularly leaving paint for a number of months. I note Craftmaster recommendations but I believe this is a polish, in my experience it brings off some of the paint as indicated by colour residue on the cloth. In other words it's doing its job by smoothing out the surface and removing swirls etc. I wouldn't fault it for a refresh/refurb but new paint needs wax not a polish. Any recommendations for a wax would be appreciated
Having spent a good few quid on a new paint job, my next plan is to get some wax (not polish) protection on it. I would appreciate any recommendations for an easy to use wax, as the boat is 60ft I stress easy to use. Thanks
I need to replace a logo badge (car badge size) and was hoping to use services of 3D Printing service or logo manufacturer. it's only a small piece and needs to be made from some sort of hard plastic. A long shot but hoping a forum member has a contact. I would prefer NW England but not essential. Thanks in advance
Thanks Ray T and Mrs Smelly. All noted and much appreciated
Anyone know of a rag rug/peg rug maker? I have seen a couple but they only do small ones, I am looking for a rug to be about 27" X 53". Any contacts would be appreciated
Thanks for the info
I need to replace the side bricks (hairline crack has appeared). Seems I have a choice of vermiculite or ceramic but which option to go for? As ever, advice appreciated.
I have the bungee with ball type fasteners, trouble is they quickly lose their stretch and become ineffective. I've tried various sizes thinking I may have overstretched the bungee but the result is the same. Is there a simple alternative (without fitting new securing points to the cabin sides), or is there a recommended quality bungee/ball fastener resistant to stretch? Advice appreciated.
This could be deemed a Statutory Nuisance under Environmental Protection Act. Ideally speak to the guy should be the first option but I can understand everyone may not be comfortable with doing this. Better still send him a letter or deliver a letter outlining the problem and identifying a solution such as turn off at 8pm. Assuming this doesn't work or you are not keen on approaching the chap, the first point of call is the Local Authority in person armed with a log of events. If neighbours are affected get them to agree to support your case. Local authority cut backs does not relieve them from their statutory responsibilities so don't let them fob you off. You can take a private action against the offender for very little cost and is not overly complicated as a DIY initiative but if you engage a lawyer the cost will run up. Local Citizens Advice may be able to help. Action could be collective if your neighbours are with you and will share the cost. Above all do not adopt any of the stupid suggestions such as chucking water on the generator or spuds up the exhaust or anything of the sort
This is a real sod. First hire boat with spouse from here donkey's years ago
Which soundbar do you have, is it 12v?
