Phoenix_V
Everything posted by Phoenix_V
  4. If you do replace there are cheaper options out there this one for example https://www.force4.co.uk/item/Lavac/Popular-Toilet/G8Z (though note flushing water can not be taken from the boat supply as with Vetus) there are even cheaper ones
  5. dont forget the higher power consumption of larger tvs if you are cruising
  6. This seems to be a more balanced report but who knows these days https://www.theconstructionindex.co.uk/news/view/bursting-the-hvo-bubble
  7. evidence Ian?
  8. A lot of suppliers claim no palm oil used.
  9. cheaper than chucking your engine out and replacing with electric no?
  10. This simple enough? https://www.ebay.co.uk/itm/20L-Solar-Power-Water-Shower-Camping-Portable-Seaside-Sun-Compact-Heated-Outdoor-/175217173656?_trksid=p2349526.m4383.l4275.c10
  13. the principal seems plausible there are plenty of electric composters out there which turn kitchen waste to compost in a few hours so a higher temperature to deal with pathogens????
  14. think i might have found the solution, only available in America apparently but can only be a matter of time? https://peoplepoweredmachines.com/biodogradablebags/biocompet.htm# "bioCOMpet provides home gardeners with a source of rich, organic fertilizer. There is something uniquely satisfying about witnessing the entire food chain: from garden to table, to garden again. Two Chamber System Add waste any time to the upper chamber, when full, transfer to the lower chamber and start over again. The lower chamber keeps curing. Internal temperature: 160 degrees F. Produce fresh compost in just 2 weeks. Automatic mixing, heating, air pump, and air filter technology. Can Process up to 5 lbs of food or pet waste per day with a 4 gallon weekly capacity. Can Process up to 5 lbs. of food or pet waste per day with a 4 gallon weekly capacity. Double reinforced, metal motor gears to help grind waste more efficiently and an internal release mechanism for jams. Accepts, meat, fish, dairy, food remains, pet waste and bioDOGradable compostable pet waste bags. Get Started Immediately Control panel with 3 power settings: High, Medium, and Low. Comes assembled with everything you need to get started with including power supply, baking soda, and 3 pound box of sawdust pellets. Food Guide and Quick Guide to help you learn about the composting process. Energy-Efficient Construction Made 1mm recycled & recyclable materials stamped with the “5” triangle recycling symbol. Energy efficient. Compatible to run with battery or solar panel."
  15. they all work on nice new clean steel, the issue is how well they work when there is a load of rust on the other side !
  16. you dont think 2 million appears a little high even if listed
  17. I agree with you, they are chronically underfunded, what should be a national asset is being allowed to deteriorate beyond help. Nevertheless they could spend the money they have on other things that 2 million pound accomodation bridges.
  18. Any use? found on a previous thread
  19. It was a view based on relevant experience, the above only serves to reinforce. If you don't have money to maintain the track of the canal why waste it on stuff like this even at half the price and at that cost!!!!!!!!!!!!
  20. and yet my suggestion on another thread that crt might not be the most efficient (at canal maintenance) was rubbished
  21. especially considering that it would have been like that for at least 45 years to my knowledge and probably 87 years
