Found a moment to look for it... I was reading the blurb at the bottom of this page about the various charging options from alternator:
https://sterling-power.com/products/split-charge-diodes-70-200a-2-3-outputs
Probably unrelated to what you are discussing or sales blurb... I've just been injesting this stuff all day.
"2) Split charge relay. This system is both dated and extremely dangerous, unless understood and the correct relay used for the correct job, ie current limiting relays may be required for safety reasons. The good side is, that it is easy to fit and requires no alterations to the standard engine system, but, it merely connects the domestic battery bank to the engine battery via a relay, which is energised when the engine starts.
The bad side (and the very dangerous side) is that a relay is prone to over loading. Say, for example, you have a 70A relay on your system and a 55A alternator, all seems great, but if you fit a 1500W inverter which can draw 150A and one morning the domestic battery is flat. So, you start the engine to charge the domestic batteries, the 70A split charger relay will come online to enable the alternator to charge the domestic battery bank. Then you load your inverter to 150A, the 150A will not be drawn from the domestic battery because it is flat but can be drawn from the engine battery (which is full). That means you will draw 150A up the split charge cable and through the 70A relay. If you are lucky you will destroy the relay, if you are not so lucky then you will set fire to the cross over cables, hence the dangerous aspect, A Sterling Currint limiting relay prevents this problem. (see later) The system must be suitable for the purpose for which it is installed and this is clearly not. "
