Yes we did, we noticed no flow at all. To be honest had we gone without any research we would never have realised the river was flowing into the canal!
Hi,
We are looking to navigate this stretch this coming weekend. CRT says -
Navigation between Stoke Bruerne Lock 20 and Cosgrove Lock 21 is now possible with care. Please be aware of strong currents and an increase in water levels due to adverse weather.
Anything in particular we should be aware of? I assume it would not be sensible to moor up here overnight?
Hi,
I have a similar Morse controller which is very stiff (especialliy in reverse) to move past the initial movement into gear. Should I try and reduce the friction as described in this thread or should I be dong somthing else to loosen it up a bit?
Hi,
We were thinking of going from Napton to Warwick next week, but apparently HS2 has closed the navigation Between Bridge 30 Welsh Road and Bridge 31 Longhole Bridge near Ufton (is it really closed?) until 1st of March. The CRT site says Upstream winding hole: Winding Hole Nimrod and Winding Hole 2, where are these winding holes? I can't find them on a any map!
Yes two warning lamps both go out when I start the engine.
No strange smells from batteries - they are sealed units.
I will check for hot spots when I next run the engine for a reasonable time. (BTW with engine running voltmeter on board says appr 14v - not that I think it is very accurate)
Sorry if I appear a bit paranoid - I have lots of practical experience of older classic petrol cars but little of diesel and leisure systems - and have never had to be fully reliant on them for periods of time!
Yes two charging lamps on engine board! So according to that everything working fine.
Only indication that somthing might be wrong is the inverter/charger warming up enough to run it's cooling fan. (No smells or hot spots)
Yes I do have a multi meter where how do I use it?
Having gone for a long trip (6 hours) I would have expected my house battery bank to be pretty much full. On plugging back into the shoreline and puting my inverter to charge (its a Victron inverter /charger) it seemed to be working hard to charge the house batteries (it's cooling fan was on for at least 3-4 hours).
Is there any (easy!) way of telling wether my leisure battery alternator battery is working? I assume the alternator warning light on the engine display is for the engine battery and alternator is for that system only. the only other indicator I have is a voltage indicator on the electric switchboard?
Given that there seems to be a google map for everything these days, is there a map for good parking near canals somwhere? (especially interested in Braunston / midlands area)
Hi,
Having had the (very Rotten) pump out tank removed from our boat and replaced with a cassette toilet we have noticed a slight list due to the lack of weight on that side - most noticible in that the shower does not drain to the plughole anymore.
The tank was on the floor boards and so the floor boards have not been lifted and I do not want to ripout the bed etc to get the floor lifted to play with the balast under the floor. I think that the removed tank must have weighed approx 160KG empty so I am proposing to stack concrete slabs/bricks or similar in the space left by the tank , ideally next to the side of the boat so that we can use the remaining space for storage. Does this sound reasonable? Any tips or better solutions?
