Slow progress over the summer; I needed to get Mike to put more steel struts in the roof, but once that was done things were a little more solid. Inside steelwork got nearly as much paint as outside; red primer, 2 coats of grey undercoat and then a layer of domestic gloss. I could then put some battens in - inch and a half for below the gunwhale (matching the depth of the existing strengthening strut) and inch for above, again matching the metalwork. Although I did use grab glue on these, they were all alos held mechanically, screwed in in various ways, some using small homemade L shaped brackets, one arm of which was rivert to the square section metal struts. I've put in lengths of 18mm ply directly under the gunwhales; the sides overlap the gunwhale internally, so the battens could be be screwed into that via 4mm holes in this overlap. I got through a fair few 4mmm drill bits, I must admit.
Again with half an eye on future condensation, I used sprayfoam insulation, a DIY kit. It suited me to do it myself, whilst saving myself some money it is was probably 50:50 whether it would have been worth getting a professional in. Anyway, the tanks were warmed up courtesy of Tony on Highlander's bath, and it went in OK, even under the floorboards in the outer thirds of the floor (some of which may need to come out for ballast in time). I wasn't sure how easy it would be to cut out the surplus, but a large panel saw did the job fine, which meant I could really go for it on the second pass.
It's made a huge change - the boat is now of course warmer, reatains heat for longer - and also quieter inside. It sounds like other people's boats do, rather than a tin box, which of course it was.
I've started on the lining itself, putting in the boards under the gunwhales first. Some of the sheets of ply have got water damaged whilst on the roof (I actually couldn't get them inside until the flimsy front wooden doors were actually taken out completely), so the worst bits have been placed whether they won't be seen when fitted out.
