Claude
    Not Telling
  • Duplicate ID
    Blackrose
Claude's Achievements
Collaborator
Collaborator (5/12)
21
  1. Why does it concern you? Everything I post is checked before it goes on. Please mind your own business.
  2. Thanks, I'll come and have a look.
  3. Yes, an attempt to avoid moderation that didn't work. I'm fully moderated on any account owing to my bad behaviour. I've never seen it flood here, I was just going by what my neighbours say and EA data. Nobody here has ever seen it go over the bank. Mind you the longest has only been here 7 years and I've no idea how long the EA data goes back. Probably not very long.
  4. Not sure yet, I haven't had a chance to go anywhere. But there is a good youtube video of Peterborough to Northampton on this forum which fills me with hope.
  5. Don't worry I'm not hanging around on this forum longer than I need to, but where else can one get information from other boaters? BTW it wasn't the politics ban, it was the science ban that made me flounce.
  6. Didn't you see my last thread with the craning videos? It's in general boating somewhere.
  7. Houses don't float full stop. Having been in lots of floods on my boat and seen the houses around I know which I'd rather be living in. Just my personal experience. I'm sure some people would rather get off their boat and that's fine. How did Tree lose their boat at Billing? I thought they were on floating pontoons?
  8. Because I'm one of those unusual boaters who speaks to their fellow moorers.
  9. Because I'm one of those unusual boaters who speaks to their fellow moorers.
  10. It's currently 0.45m at Cogenhooe according to the EA and the highest ever recorded level is 1.24m above datum. Even if it rose 0.79m to its highest ever recorded level it would be only be about a foot over this bank and I could easily get on and off with a pair of wellies or waders so I don't really understand what the panic is all about.
  11. Which model is that? I have a Zanussi ZWC1300W which I sometimes run from a Honda EU30i. The generator is supposed to have a pure sinewave output but sometimes the washing machine hesitates for 20 minutes before it will start from the generator. Other times it starts straight away. I can live with it, but it's a real head scratcher...
  12. I have the smaller version (Nature Pure) made by the same company. It comes with a dedicated tap so you're not filtering the entire system, just drinking water. They're not cheap, but they are very good.
  13. It's definitely the bollard. I've just plugged into the other bollard and the charger is working fine.
  14. Even the best blacking job with bitumen will only last about 3 years so there's an optimum point at which the effort that goes into it shouldn't surpass the result. I once went around my boat after pressure washing to prep and remove old flaking paint, before applying 2 coats of Rylards Rytex and 2 coats of Rylards Premium. That's 4 coats of bitumen. I did it all myself over a week and was very proud of the job, however it still only lasted 3 years, so probably not worth all that effort. As a rule of thumb, when you start to see rust on the waterline you've probably got another year to get the boat out of the water. This assumes normal corrosion and the boat has anodes, not accelerated galvanic corrosion. I used to worry when I saw rust on the waterline, but every time the boat has come out the water (a year after first seeing the rust) I've wire brushed the area and it was just surface rust without pitting.
  15. But still not quiet enough for domestic use in my opinion.
