Can be higher but you have to be carefull as some of the water in the pipe between the pump and shower tray will not get pumped away and can run back into shower tray.so keep pipe short instructions are good regarding fitting
I want to have a single battery powering my Wallas oven and hob with a seperate battery and its own solar panel and wiring with the exhaust for the oven hob exiting through the steel of the boat,can any one see a problem with two 12 volt systems on a boat? Reason I would like to do this is my boat has no gas and I would like to know that the Wallas will run even if the main battery's are low as the hob will also work as a heater if my main heater fails so it's also a back up system
Thanks for all the healpfull replies to my other questions and hope this is not a daft question
I took mine back to bare metal hard work but easier to flat off and repainted with no worry of reactions of different paints but sure someone will know better than me
get second hand stuff does not need to be expensive since buying a boat Ilike using a centre pin and float fish have a folding net I believe Aldi are doing fishing gear on Sunday fifty pounds should easy get you started
Hi
Would anyone be able to advise me where I can buy a RFI suppression board part number E000-22080 it has Newage international on the label and its powered from a beta mini prop gen Markon sl105g 7kw generator. Had a little electrical problem on the boat and noticed the capacitor/diode leaking but the system seems to be working ok.would like to buy a new unit if possible.
Thanks any help or advise welcome
Chevron
To be awarded that sort of money is a joke, I am deaf and enjoy cycling and walking if a bike comes from behind me whist I am walking I dont have a clue its there cyclist dont understand that I have not heard them and think your being difficult when you dont react and get out of the way.A cyclist should always have to slow when approching a hazard so if needed they can stop in a controled manor without causing a hazard to other persons.If I go out on by bike I hope that the way I ride my bike improves the relationship between cyclist and other users of the towpaths and trails
I would be asking for a long maybe ten mile test run in the direction you were going to take the boat home, broker driving if all ok then handing the money over,its the least they should offer now there has been a problem, Engine running and reving in the boat yard is not the same as underload make sure your happy before parting with money. Good luck hope all goes well.
Hi
Hope someone can advise or point me in a direction of the information i need. have a bubble stove with a back boiler which supplies a simple large bore copper pipe which runs the length of the boat in a loop back to the boiler on rear of the bubble stove the system was fitted when the boat was new ,It has a water supply with an isolation tap for filling the system and has a Zilmet - 10 Litre Flat Expansion Vessel with a pressure release valve and gauge, the system when the bubble stove is turned up goes to 2.8 bar and then I get a slight drip from the pressure release valve which has 3. bar stamped on it.My questions are once I have bleed the system to get air out of it should the isolation tap be closed so its a closed system relying on the Zilmet - 10 Litre Flat Expansion Vessel is the running pressure of 2.8bar because I am leaving the water pressure supply turned on? what sort of pressure should the Zilmet - 10 Litre Flat Expansion Vessel be set at via a pump? what sort of pressure should the sysytem run at?
Many thanks for all the advice I have received on my other questions
I have only had the boat a few months and its an all electric boat with a beta engine generater set. the wiring is in place for battery leads for an inverter and it looks like the inverter which has been removed before I bought the boat had a 240volt lead going into the inverter and a 240 volt coming out auto switching I beleive this is called? as these have been joined together so no break in 240volt system from the shore line . the victron I have bought does not have this function and will be wired through a three way switch when I can get a electrician out to do this. my problem is I intend to next week take the boat from its mooring and shore line for a weeks cruise, my boat has a mains fridge which I need to supply constant 240volts.I intend just to connect the inverter lead with correct 16 amp socket to where I have disconnected the shore line at the boat just for this 7 day cruise
Hi
As a tempory solution is it ok to make a wire and plug an inverter into the shore socket to provide 230 voltage till a three way switch can be installed properly?
Hi
Might be a daft question looking at this victron inverter on ebay http://www.ebay.co.uk/itm/Victron-12-Volt-Multiplus-Inverter-Charger-12-2000-80-120-Volt-/271795688369?hash=item3f484913b1its a Victron 12 Volt Multiplus Inverter Charger 12/2000/80/120 Volt what is worrying me is the 120volt output how do I get this to work with uk voltage?is it me am I missing a simple solution?
Needed some new hatch seals for my boat spoke to Sally at eagle boat windows and she recommended two seals for my hatches, ordered the seals and they arrived the next day and fitted perfectly following the instructions she gave me.. I would not hessitate to order from them again great customer service.
Eagle Boat Windows
Unit 9, Kenyon Court
Kenyon Road
Lomeshaye Industrial Estate
Nelson
Lancashire
BB9 5TF
Boats I have seen all had a battery near the bow thruster charged by a seperate battery charger.dont know much about bow thrusters but dont they get used in short bursts.would love to see your thread on paint work just bought a boat with need of paint and need some inpiration
Thanks for all the help I have emailed Andy as suggested above regarding what and if he has had any problems on his boat Whisper with this prop gen system
Thanks for the replies Ray has got which system it is there seems to be a few boats fitted with this system it has a ac generator shaft driven via a extra fan belt and as Ray has said it alters the engine speed to 1,500rpm when cruising via an hydraulic gearbox. I am looking at a boat with this system on and am worried about how reliable it is it seems to alter the type of gearbox fitted I was hoping that maybe someone on here has the system and could advise if they have had trouble free cruising
Hi Wonder if anyone could point me in the right direction for a manual for the prop gen as fitted to a beta BV2203 also any information regarding reliability and thoughts of how good the system worked on a narrowboat
Heart goes out to you its so sad to loose a trusted friend. just focus on the good times you had together and all the joy Minty brought you.it takes time to get over the loss look after your self and keep busy
Hi This is my first post so please be gentle with me
I am looking at buying a boat and twelve months ago looked at a boat called Lichen Lady a seventy foot boat built by Ian Kemp and fitted out by Dave Freeman.When I looked at the boat it was in a poor state for a 1995 boat? and being smartened up by the owner the boat now is up for sale.Does anyone know any thing about this boat someone told me the poor condition at the time was due to water damage.I now have the funds to buy a boat and keep going back to this boat does anyone know the history or anything about this boat?
