Everything posted by canals are us?
Glad you got sorted. James.
Hi, Its the old version of the current LAP branded digital immersion heater timer from Screwfix. https://www.screwfix.com/p/lap-7-day-digital-immersion-timer/1804R?tc=ST2&ds_kid=92700019931972361&ds_rl=1241687&ds_rl=1245250&ds_rl=1249401&ds_rl=1248154&ds_rl=1245250&ds_rl=1247848&gclid=EAIaIQobChMI05-HoePV4wIVC7DtCh059gY7EAQYAiABEgKT6PD_BwE&gclsrc=aw.ds I have the same one as yours installed about 5 years ago for my 1.1kw immersion heater. Its worked great but it's biggest problem is it's not backlit, so you need a torch to set it etc. Update it to the new version!! To see if it works press the on/off/auto button while shining a torch at the display to on in the window appears. Make sure on mains landline not inverter! The red light will come on if mains present and water being heated. To set the timer from memory use timer button then hour/min buttons. display shows on time in window. set off same way and also select days Mon-Friday or Monday-sunday Has setting for several on/off times during each day. I have my immersion set for 7 days a week with one on time at 16.30 and off at 1800. If mine packs up I'll buy the new version as has light built in to the display!!
I bought my 1999 50ft Liverpool trad nearly 7 years ago for 25k and have to say it's been great. I'm self employed on a small less than 10k a year income and find the boat perfect for me. I probably wouldn't get a mortgage for a house and couldn't afford a monthly rent. My boat costs are reasonable. £2,400 for residential mooring in Midlands Marina. £800 boat licence. Blacking every 2-3 years £500. Gas bottle one a year, last one cost £28.50. Just use gas hob. Shore power £10 a week. Use mini oven. Washer/dryer and dishwasher. Insurance £150 a year Heating by multifuel stove £20 a week. Plus £60 worth of diesel a winter for webasto. I have updated most of the interior adding my stamp to it mainly galley and walk through bathroom and updating electrics as added inverter, solar etc. Just finished installing an engineered oak floor in galley, bathroom and bedroom and a new thetford loo as old C200 loo well past it! The more you can do the better. September my boat is getting blacked and new anodes fitted as anodes nearly gone at nearly 7 years old. My advice is if buying a smaller boat gets you a better, newer boat go for that. I could probably live on a 40ft trad if I had too. Good luck with you search. James.
I have 380 watts and a 40A tracer MPPT controller. No idea what it will run but most mornings when sunny reading 14-15 volts. I'm Marina based and so plugged in to shore power. I have a 12 volt under counter fridge and separate 12 volt under counter freezer, which are my boats main power usage items. 12 volt TV. LED lights. pump etc. Batteries 4 x Trojan T105's One pair very old like 5 years other pair 18 months old. Must get out soon and try it out! James
A 23ft springer water bug that we have was overplated in 4mm steel in 2017 by the previous owner due to pitting, and when we bought, the gas locker drain was on the water line or under if someone is on board. The extra weight of plating and new fireplace and stove etc have added extra weight. Plan to get the boat blacked this summer, have hole welded up and re-drill new hole higher up and rust treat floor and install new gas locker floor higher up level with new hole. May modify locker lid higher to fit a larger gas bottle at the same time. Then a outside paint job. James.
My Washer/Dryer is in the Galley along with the 12 volt fridge and freezer and dishwasher. My boat is a 50ft trad, originally with corridor shower room, as first picture. I re did the galley around 4 years ago and made a walk through bathroom. This enabled me to have units down both sides, so I could fit everything in. Need to change the laminated oak effect floor and re-paint the units. James.
Ordered 2 new batteries from Tayna batteries, so awaiting them. Budget at £69 each. I found that connecting the charger to the battery at 10 volts the charger fired straight up. Thankfully not getting warm and will be binned when the new batteries arrive. Many thanks. James.
Thanks for the advice. I started it up 6 days ago after around 8 weeks not started and engine took a while to start, blowing out white smoke, then fired up and ran clear. I had forgotten to turn off the charger then so may of blown the fuse! James.
Thetford C200 Loo. Any good deals.
canals are us? replied to canals are us?'s topic in Boat Equipment
I thought about buying the seals and re-furbishing them but the plastic is scratched and faded. Toilet seal to tank failed and pressure release on cassettes leaking and generally shabby. Probably bought from late 99-2002. I bet the cassettes are different! If so I'll give the old cassettes away! Thanks. James. -
For the last 6 years I have a woodwarm fireview and its great. Very controllable and good quality. Made in Devon. Not cheap then at £795. Have back boiler on it £145) to heat 2 rads on my 50ft trad narrow boat. Simply great. Have a look at Clearview and woodwarm. Also like Dunsley Stoves and Contura. My Sister bought a boat and we went cheap and cheerful with her stove. A 4kw hamlet hardy 4 by arada. £269 Delivered from plumbnation before Christmas. Steel bodied and cast door. It works OK and quality is good. Riddling grate could clear more ash and glass not totally clean but good value for money.
Sadly there is no volt meter on the boat or battery monitor and I have been away twice working for 5 and 4 weeks and my Sister wouldn't know how to use a multi meter or even think of looking at her batteries. When I installed it I seem to think the charger function was odd as it went to float too early so suspected batteries full as had ben cruised for 7 days ,54 miles, being delivered and though batteries were nearly full at 12.5 volt and so gone to float. I cant remember fully as busy with other work but sure I measured the batteries float voltage around 13.2v. I'll get a digital volt display from ebay and wire it in. I find mine useful as well as a NASA BM2 and MT50 solar Meter on my boat. I'll get my Sister to buy new batteries and I'll fit them and see if I get an increase in volts to indicate the charger is working. The charger has printed the float charge to look for and bulk charge. Certainly when I run her engine I got 14.2 volts at the batteries. James.
The boat never had any mains on board so wired in a consumer unit and sockets and as my Sister is spending time on board wanted to wire in my old 4 year old battery charger to run lights and fridge. I remember after buying the boat the batteries were at 12.5 volts. can't remember if I measured output with charger on but charger been switched on for 3 months same as fridge. My suspicion is charger US and killed of batteries. Many Thanks. James.
This is how I wired it. charger output positive to domestic positive and negative to common negative. I can see the black cable going to the domestic negative then link from domestic to starter. Originally I had a 15 amp fuse in the positive lead to the batteries and yesterday it blew a 15 amp fuse 3 times when fitting. I put a 30amp fuse in and not blown so far sine yesterday. Also the charger has a 25 amp fuse and that is fine. Terminals are ring type and crimped. Many thanks. James.
Yes. The fused output positive connected to the positive of one battery and the negative on the same battery. No, mostly not in use, but fridge on with a few items in it. Batteries not looked at electrolyte level but the batteries look old. The charger has 2 lit led's one to show mains on ie red. 2nd LED red to show charging and green to show in float. Thanks. James.
Thanks everyone. What I don't get is why didn't the mains 20amp battery charger not charge the batteries as needed as connected and on ever since turning on the 12 volt fridge? I don't want to buy new batteries and wreck them. Yes domestic battery 3.6v and starter 10 volt. I'll get new ones. My thinking was I could use the capacity of the 2 batteries, 110A each for fridge and the mains charger keep them charged. James.
I'm in need of replacing my C200 Loo, as well past it's best, faded and leaking! All seals needed and on cassettes. I found a caravan supplier with the cold water flush and it was £380 but ideally want a spare cassette as well. Has anyone found any good offers or recommended suppliers? Anyone have this version? Any better alternatives? https://www.jacksonsleisure.com/caravan-motorhome/toilets/cassette-toilets/thetford-c223cs-caravan-motorhome-cassette-toilet/ Many thanks. James.
My Sister has a Springer Water bug with inboard diesel engine with single alternator with one domestic battery and one starter battery connected with a 4 way rotary switch. marked Off 1,2 or both. Around 3 months ago I fitted a single output 20amp electroquest battery charger connecting the fused output to one of the batteries and negative on opposite same batteries negative terminal and kept the main rotary switch set at both, thinking the charger would charge both batteries. When I fitted it I couldn't tell if it was working as went both red then to green very quickly. There is an old Engel 12 volt fridge and the batteries are both flat now as had fridge on for 2-3months. Battery with charger connected reading 3.7 volts and other battery 10.2 volts. On setting 1 and 2 got around 7.5 volts each from my multi-meter. can you wire up a single output charger to a bank with a rotary switch? If so how? Also suspect duff switch as get no power to lights in the both position. Originally it worked up until now. The 2 positive cables goes from the rotary switch separately to each battery and the negative is shared and joins each battery negative. Will a charger charge really flat batteries? Tried starting the engine and no start in any rotary switch position. Like to get this sorted. 12 volt wise we have 5 LED lights and the slimline engel 12 volt fridge. Any ideas what the issue is? Tomorrow I'll take some pictures of the battery wiring and rotary switch. May even try separating the 10 volt battery and fitting charger direct to confirm if charger actually works. Many thanks. James.
Springer engine identification.
canals are us? replied to canals are us?'s topic in Boat Building & Maintenance
Thanks everyone. So could be a Vetus/ Mitsubishi/ Kubota engine or a mixture of all! Were they any good? Sounds like a motorbike when revved. It also has an oil removal pump like my BETA. The boat is supposed to be from 1991, but who knows when it was actually built. James -
Thanks everyone. James -
Thanks everyone. Next time I'm at the boat I'll see if there is any plate or name cast into the engine. James -
I used to have a Challenge extreme chop saw, but after working at the Isle Of Wight can't find it anywhere. I accidently left the passenger window open, so suspect someone reached in through the passenger window and unlocked the rear door and took it off the back seat from under the dust sheets! I didn't use it a lot but it did the job really well as used it on several house renovations. Could cut boards over 300mm wide. I wouldn't buy expensive tools as may get stolen. It cost just over £100 10-15 years ago from Argos from memory. James
Recently we bought a springer waterbug with inboard diesel and wondered what engine it is? Where can I get oil/fuel filters for it and what type? How much oil does it take and grade? Want to change oil in the next month or two. Is it a reliable engine, anything needing attention? Sounds 2 cylinder and had no issues in the 50 mile cruise, apart from using 1/2 a litre a day of coolant. Going to check hoses etc. Do you know where I can get a replacement oil dipstick as it seems the end is broken off. Any with the same engine can you photo the end of the dipstick for me and length? Here are a few pictures of engine. Spring, clean and paint engine bay and exterior. Have to say I like it. Small but well laid out. So far fitted a 240 volt landline. SFS and fireplace where 2nd dinette would of been. Replaced ceiling. Painted all of the interior and removed top half of wardrobe. Summer repaint exterior and locker and engine bay. Many thanks. James.
